Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 01-30-2012, 11:28 AM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
WRX 2.0 rebuild
Ok, I'm not a newbie to rebuilding engines... if they are the V or inline versions. Never rebuilt a flat 4 and can't imagine it's much different.
My step son spun 2 rod bearings, 1 and 4. Not much for metal shavings throughout that I could see upon initial inspection but that only included the bottom of the pan, and the oil pick up screen.
The engine has not been pulled yet and I still have to look at and/or measure the cylinder walls, pistons, rings, ring clearances, cranks shaft journals, connecting rods, etc.
I know we can reuse headbolts and block through bolts, etc.
So here is my question, assuming I measure and tolerences come back as still within specs, is there anything aside from rod bearings, main bearings, and a complete gasket set that I should consider replacing on this motor?
It has +/-76,000 miles on it. He has limited funds to work with. Again, assuming much without pulling the engine, I can pull it, boil it, turn the crank, get oversized bearings, replace all gaskets, and update the oil pickup for about $800.
Minumum on a shortblock that I've found is about $1650 and that doesn't include a master gasket set for $250ish plus an upgraded pickup for about the same.
Any thoughts would be much appreciated.
Thank you in advance,
Michael
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 05-28-2013, 05:46 PM
brokenboxer01 brokenboxer01 is offline
Re: WRX 2.0 rebuild
Mike,
I have four of these EJ20 rebuilds going at all times, on top of allot of EJ25 rebuilds. Subaru cranks can't be turned for a variety of reason. First and foremost they are already pretty small in diameter. Secondly finding a shop setup for them is a challenge even if you wanted to. The small journal diameter would require a shop to have a wheel setup specifically for the boxer engines. Pretty much assume the crank is junk. Even the new cranks are on the skinny end of the spec from the box. Also be sure to not reuse the oil cooler. Generally speaking I bypass the cooler after a rebuild. They do not flow enough to do much more than help cold starts. Very simple to bypass, all the parts can be removed from a N/A suby. Head bolts are another issue with the build, for the small additional cost it's great insurance to go with ARP's. Truly a night and day difference. If you are going to do all the work your self, I would put the saved money to a new crank, good bearings & studs. Your goals of 800.00 will be cutting it close.
1994 f150 5.0 rebuild spoovey F Series 4 03-19-2010 06:30 PM
90 eclipse 2.0 turbo 5sp rebuild problem 03impala9c1 Eclipse Problem Diagnosis 0 03-16-2008 09:59 PM
Can i swap my 1.8L flat four for a 2.0 turbo WRX engine and tranny? TakimotoRacing Impreza/9-2x/Outback Sport 1 09-06-2004 01:16 PM
Rebuilding a 91 16V 2.0 drewbevins Jetta/Vento/Bora 0 01-18-2004 12:08 AM
