Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-16-2008, 09:59 PM
03impala9c1 03impala9c1 is offline
90 eclipse 2.0 turbo 5sp rebuild problem
90 eclipse 5sp turbo 2.0 dohc problem
had a detonated piston number 3 i believe, so the engine was torn down block removed, rebuilt and thrown back together... brand new battery cranked over fine before hand
went to turn it over and it JUST started to crank then... POP! then nothing... now theres like no power anywhere it seems... until... i disconnect the power wire then wait a little while then reconnect it and accessories go goofy sort of but still no cranking at al or even a soleniod click for that matter... sometimes it will pop again sometimes it wont i removed the power wire again and tried to get a spark out of it between the post and terminal and dont see anything whatsoever... WTH?!?!
***5 WAYS TO KNOW YOUR A REAL MECHANIC***
1. YOU HAVE NO IDEA WHAT THE TERM "ANTI-SIEZE" IS.
2. ADD-A-WRENCH (EXTEND-A-WRENCH) IS YOUR BEST FRIEND
3. YOU KEEP A 3 FOOT PIPE IN YOUR TOOLBOX TO PUT ON THE END OF YOUR BREAKER BAR AT ALL TIMES
4. YOU HATE MECHANIX GLOVES AND USE THEM AS RAGS
5. EACH TIME YOU TAKE A SHOWER YOU SPEND MORE TIME CLEANING GREASE FROM THE SHOWER ITSELF THAN YOU SPENT CLEANING YOURSELF!!
