Old 01-30-2012, 07:21 AM
barkhorn45 barkhorn45 is offline
F-150 oxygen sensor
My ford requires a new sensor as I drive otr my wife took it to a repair shop called "american auto service"they quoted a repair cost of $950.00.This sounds a little steep to me am I correct?
Old 01-30-2012, 08:21 PM
autojoe autojoe is offline
Re: F-150 oxygen sensor
crazy.............what size engine and year?how many miles?any driveability problems?
Old 01-31-2012, 02:52 AM
Yes it is and would have to be crazy to pay that.At this same shop my wife took her 2003 buick regal in to get the a/c fan replaced and received a quote of $275.00 so she agreed and left it to be p/u later.Then she received a phone call from them stating that the only part they could find to fix it would raise the cost to $975.00!Hmm sort of steep so she told them not to replace it she'd live with the sound it was making.An hour later they called back and said they found an aftermarket part and the cost went down to $575.00.She told them the same thing no.So she goes to p/u the vehicle and they had found a after market part and did the repair for the original $275.00!!! but no warrenty.I guess they saw a woman and figured they could get away with this b/s.
As for info on trk it's a 2003 with 3.0L v6 with 108.000 miles on it and runs well in fact the service engine lites been on since 2004.The emission place I take it to turns of f the lite and I come back 2 days later and it passes.
I just replaced the original battery last month,squeezed all the life out of it I could.
Old 01-31-2012, 07:35 AM
the 02 sensor should only cost around 80 dollars for a bosch.....an oe one would cost a lot more.most shops in my area use aftermarket.plus diagnostic charge plus labor to install.f150 with 3.0?what kind of noise?at that mileage probably good to replace all 02s if original.what code number?
Old 02-07-2012, 01:37 PM
BigF150 BigF150 is offline
Sorry to sound out of place, but what does an O2 Sensor do? I know for outboards in boats they have a Carbon Monoxide Blower, but I have never heard of an Oxygen sensor.
Old 02-07-2012, 06:37 PM
P_A_B's Avatar
P_A_B P_A_B is offline
Basically, trying to make it simple, the O2 sensor, as the name says, checks the oxygen going into the cat and coming out of it. there are several uses to this. First, the O2 sensor can tell you if the cat is good or not. Secondly, the O2 sensor is what the PCM uses to make sure the engine is getting the right amount of fuel. Through the O2 sensor, the PCM can tell whether or not the car is running rich or lean. Thus, changing the amount of fuel or air, depending on the need.
Old 02-16-2012, 12:22 PM
crobar1 crobar1 is offline
Smile Re: F-150 oxygen sensor
Thanks for that info!!
When I change the sensor will that automatically reset the code and shut off that darn "Check Engine" light. 1996 F150 5.8 ltr
Old 02-16-2012, 12:58 PM
P_A_B's Avatar
Not necessarily. I have actually seen it go both ways. I've seen some engine lights come off, but other times it needed to be cleared. Hopefully it will turn off automatically, But if it does not, before you clear the code, make sure the O2 sensor was bad, and not something else. O2 sensor checks many things, so if PCM says its bad, it might be because of an exhaust leak or something else.
Good luck!
Oxygen Sensor sasheehan Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 6 04-01-2012 08:19 PM
Cleaning O2 Sensors CCMphysician Engineering/ Technical 4 01-15-2010 07:47 AM
97 camry V6 02 sensor help!! machinehead26 Camry/Camry Hybrid/Vista 3 10-25-2009 07:44 PM
is it weird my oxygen sensots voltage changes WHEN THEY'RE UNPLUGGED? bac512 Savana 0 07-29-2009 10:20 PM
o2 sensor danielgast46 F Series 0 03-15-2009 09:39 PM
