Go Back   Automotive Forums Car Chat > Saturn > Aura
Old 01-29-2012, 05:25 AM
MadMaxGT MadMaxGT is offline
HELP! 08 Aura XE no power, Will not start, not dead battery!
Ok, I had a problem with drivers seat belt, so pulled it and sent it out for repair. Started car every few days while waiting for belt to return.
Today I removed the negative terminal and reinstalled the seatbelt. Replaced the terminal, car is dead? No power no interior light, no dash lights, no sounds completely dead nothing!
Tried to jump, still nothing, "and I mean nothing dead"???
Purchased brand new Battery, stumped as to what's wrong? Any advice is greatly appreciated!
Max
Old 01-29-2012, 08:39 AM
DeltaP DeltaP is offline
Re: HELP! 08 Aura XE no power, Will not start, not dead battery!
Gotta be something with the batt cables. Check fuses,links also. I would think a 4 year old seat belt would still be under warranty. I also wouldn't dream of trying to repair one.
Old 01-29-2012, 11:32 AM
Long story, seatbelt is no longer under warranty, and I had it sent out for a professional repair.
Do you know if there is two fuse boxes? where is the inside one located?
Thanks
Old 01-29-2012, 12:30 PM
Thanks
Thanks for the replies, I really did take the time to closely examine both pos and neg cables. The positive side has two lines, so i also used a test light to confirm I have power down at the starter and over to the terminal connection at the top of the fuse box. Found the inside fuse box, all fuses inside and out are OK! No power anywhere else! Stumped?
Old 01-30-2012, 09:55 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
I see that you are on your way to diagnosing this on your own; if you were to ever decide to work with a dealership, please let me know as I would like to be available to assist!
Sarah
GM Customer Service
2003 Alero will not start, only service engine light comes on with key turned to ACC DelbertJay Alero 2 02-20-2012 04:05 PM
2000 Kia Sportage died on fwy. Will Turn over but not start...HELP over_kia Sportage 3 10-16-2010 02:11 AM
98 mustang gt will not start after negative battery terminal went bad bratt Mustang Problem Diagnosis 6 07-24-2009 06:07 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
1993 Mercury Tracer - Ford Escort-Will not start-has good battery mrfixit34 General Discussion 2 02-04-2006 03:01 AM
