Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-23-2009, 05:33 PM
bratt bratt is offline
Question 98 mustang gt will not start after negative battery terminal went bad
well i was driving fine and then the car shut off completely.
i had no power so I knew it was the battery.
my negative battery terminal was corroded. I replaced it now the car still does not start.
I checked the fuel and I have fuel pressure and the pump primes the fuel lines every key on.
I checked the spark and wow, I got shocked good cuz I was holding the coil and my tester lighted up.
someone said maybe my injectors are not injecting. some sort of eec or injector relay has to be checked but how do I do this?
Old 07-23-2009, 06:31 PM
rhandwor rhandwor is offline
Re: 98 mustang gt will not start after negative battery terminal went bad
Look at the electrical power center it has a black cover remove the cover. The relays are marked hold your finger on one at a time have somebody crank the motor. You can feel them click. Look for a blown fuse while your in the box.
http://www.autopart.com/tools/toolsmain/tool/T_3401.htm
Use one of these to check for power to the injectors.
Old 07-24-2009, 07:34 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Have you scanned the car for codes? That is alway the first thing I do.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 07-24-2009, 09:12 AM
buhweet1 buhweet1 is offline
Does the car turn over at all, and did you replace the entire cable back to the engine?
Old 07-24-2009, 09:26 AM
No I did not change the entire cable back to the motor.
The car starter does turn the motor quickly yes.
I have spark, I have fuel pressure, and the injectors work.
Old 07-24-2009, 12:30 PM
Your fuel doesn't have water in it does it?
Old 07-24-2009, 06:07 PM
no the tank has good gas. I squirted some out of the fuel rail is good gas
