Old 01-26-2012, 06:39 PM
Bobellen Bobellen is offline
2003 Alero Fan doesn't work.
For a while now when i would turn my fan on, from off, the lights showing the air inflow, etc. fade out and i get no air intake what so ever. The light is on when the dial is switched into the off position, but when i go from level 1 and up the power dies out. Intermittently it will turn on, but often for brief moments of time. Also when it IS on i get a permanent "cruise" light that stays on however my cruise control doesnt work when this is going on. The light is just on. When it does decide to work and i turn my cruise control on it works up until my fan dies out again (they are on and off at the same times) and thus, the cruise control dies again. I took apart my heater circuit board in hopes that it would solve the problem, and for about a week it did. However it ceased to work yet again. I went and pulled one from a scrapped car to see if replacing the unit would solve the problem, but this one is not having any better luck. Any ideas, or professional opinions would be appreciated as im in dire need of heating in my car.
Old 01-26-2012, 06:57 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2003 Alero Fan doesn't work.
I'm thinking maybe you have an ignition switch problem. The HVAC control assy and the cruise get their power from the same leg off the ignition switch.
Old 08-02-2012, 05:43 PM
schumld schumld is offline
Did you ever figure this one out? My 2003 Alero does the same thing with my fan and cruise control, but it also affects my windows and blinkers. If my blower doesn't work I just hit the cruise control switch and window switches and it works again... same thing for when my windows or cruise control or blinkers don't work... hit the other switches and then everything else turns back on. Any ideas out there?
Old 02-19-2013, 07:43 AM
genegr genegr is offline
I just had my ignition switch replaced for the third time and now the heater fan doesn't work. I'll mention it to the mechanic and repost the results.
01 alero fan not working tatt4u Alero 7 12-13-2010 06:58 PM
Battery Light and Brake light come on and A/C fan doesn't work Kayleigh Rodeo | Passport | MU 14 06-27-2009 03:22 PM
Heater/AC fan doesn't work on low speeds gjthomas48 Camry/Camry Hybrid/Vista 10 07-29-2008 04:22 PM
need help with struts, and fan doesn't work joyrider Cavalier 2 02-15-2004 06:18 PM
Help Radiator Fan doesn't work!? 2fast2serious '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 09-20-2003 02:19 AM
Tags
fan , heater
