Old 01-24-2012, 03:34 PM
FishFind FishFind is offline
One Hot Shot
Harmonic Balancer squeek
The other day I notice that I had a nice wet spot under my 1998 4wd chevy blazer. Turned out to be the water pump.
I replaced the water pump and was hoping that it would also take care of a nasty squeel that I was hearing for a month or two.
Squeel is still here and makin me nuts. The only place I can guess it is comin from now is the Harmonic Balancer that I noticed looked nice and rusty from my water pump.
Does this sound like it could be the case?? if so what is the squeeking coming from? Is there a bearing on the harmonic balancer?
Old 01-24-2012, 05:14 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Harmonic Balancer squeek
If you have a Serpentine Belt (not sure about 98's) in all probability that is the root cause of your problem. I have to replace mine every 2-3 years because of the Squeek. I have found that the AutoZone Gatorback Belt lasts the longest. So change your belt and see if that helps before replacing anything else.
And BTW, you'll chase the damn squeek all around the belt system, and be tempted to replace everything from the Alternator, Power Steering Pump, Idlers, Belt tensioners, Smog pumps, to the Air Conditioning Compressors, and nothing will do it.
Start with the belt, if it is still there after replacing the belt, You can call me all kinds of names.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
The Following User Says Thank You to Rick Norwood For This Useful Post:
FishFind (01-24-2012)
Old 01-24-2012, 08:01 PM
One Hot Shot
That did it bud. I guess no name callin.
Old 01-24-2012, 08:38 PM
Big Tall Dumb Ass
Coooool!
Even a blind squirrell finds an acorn in the forest once in a while.
2000 GTP - how to re-install harmonic balancer Van2000GTP Grand Prix 1 02-24-2010 06:44 PM
How do i tell if I have a bad Harmonic Balancer shanea1 Engineering/ Technical 2 10-05-2009 05:13 PM
wobbley harmonic balancer nzyd07 Off-Topic 5 07-10-2003 04:19 AM
Help with my Harmonic Balancer cmilliron General Discussion 1 04-21-2003 02:32 AM
87 Honda Accord-removal of Harmonic balancer-bolt will NOT loosen, Now what? Snowalker Engineering/ Technical 2 07-03-2002 11:00 PM
