Old 07-05-2003, 08:21 PM
nzyd07 nzyd07 is offline
wobbley harmonic balancer
Need help tightening a wobbley harmonic balancer. How do I get to it and what do iI do once I get there. It is on a '97 Eclispe GST.
Bob
Old 07-08-2003, 09:42 AM
turboawdgsx turboawdgsx is offline
The harmonic balancer is on the timing belt side of your engine. It's the lowest pulley that has the belts attached to it. There should be 4 bolts going into it. Just use a socket (14/17?) to tighten it down. If it's separating, yo'ure going to need a new one. They're about 90-100$ from the Mitsu dealer.
Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?"
Old 07-08-2003, 08:16 PM
How do I get to it?
Bob
Old 07-08-2003, 08:29 PM
DSMChick97 DSMChick97 is offline
Send a message via AIM to DSMChick97
MY HARMONIC BALLANCER (the ring) POPPED OFF AND RESULTE IN A HORRIBLE CASE OF CRANKWALK...!!!!
Old 07-09-2003, 12:34 AM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
All you have to do is take off the tire and the fender liner, and its right there. Then use your 12mm socket and tighten that shit up
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 07-10-2003, 05:19 AM
kjewer1 kjewer1 is offline
AF - Advisor
The pulley seperates eventually on every dsm. Mine has done 3 times (160k miles). It wont cause crankwalk, but it can wear into the tbelt cover, and destroy the tbelt, costing you a head at least and a motor and head at most. Be sure it hasnt seperated. If you do jsut need to tighten it its 12mm, and the torque on those bolts is low, only about 15 foot/lbs. If you strip that auluminum sprocket you basically have to do a whole tebelt job which is at least 500 bucks at the dealer, or a half a days work if you do it yourself (only for expereienced DSMers, even the dealer doesnt do it right 90% of the time, and a "shop" will almost never do it right) Dont take anything on that side of the motor lightly
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
