Old 01-22-2012, 02:31 PM
huynh huynh is offline
1999 LeSabre air blows but no heat, please help!
Dear all,
I have a 1999 Buick LeSabre with 120K miles.
When I turn on the defrost or heat in the car at 80-85 degree (rarely turn that high), the air blows out but a lot colder. Also, when I switch from the defrost to dash or feet, the air keeps blowing to the windshield.
Any idea to help would be greatly appreciated.
Huynh
Old 01-22-2012, 06:44 PM
FishFind FishFind is offline
One Hot Shot
Re: 1999 LeSabre air blows but no heat, please help!
check switch?? maybe the vacuum lines for the blower??
The Following User Says Thank You to FishFind For This Useful Post:
huynh (06-28-2015)
Old 01-23-2012, 09:42 AM
GSGregg GSGregg is offline
Sorry, I'm not familiar with your specific system (especially not knowing whether you have manual or automatic climate control), but my bet would be vacuum. Check for a small-diameter plastic tube (probably black) coming off the engine and disappearing into the firewall; on a 13-year-old car, the plastic could have dried out and broken or its rubber connector likewise. Then, there's always the possibility that someone just left it disconnected.....
The Following User Says Thank You to GSGregg For This Useful Post:
huynh (06-28-2015)
Old 01-23-2012, 08:22 PM
Thank you, all!
I am going to check all those possibilities. The car has automatic climate control.
I have searched and found that the thermostat is also another possible cause. Recently, the car has had a leak in the intake manifold gaskets. The mechanic changed the thermostat too. I do not know if I should replace the thermostat, but I will try and see if it helps.
Old 01-23-2012, 09:26 PM
Tech II Tech II is offline
Do you have a temp gage?
When the car is at normal operating temp, feel both heater core hoses...are they both hot, both cool, or one hot and one cool?
Set your auto temp on 90, do you have heat now?
You may have a vacuum solenoid box.....if yes, I think the source vac is a purple line....check for vacuum....
The Following User Says Thank You to Tech II For This Useful Post:
huynh (06-28-2015)
Blows Constant Heat!! Please Help! blrmkr Cutlass Series 2 08-26-2007 07:17 PM
blowing gauges fuse...please help malletslinger Camaro Discussions 36 02-12-2006 11:45 PM
1999 pontiac Montana is over heating please help pandacare Montana/Montana SV6 6 12-15-2005 03:42 PM
94 lesabre fuel pump relay location - please help skooby05 LeSabre 4 07-07-2005 04:04 AM
92 Buick LeSabre-Headlights Won't Come One-Please Help! JESSICAR LeSabre 5 08-02-2004 12:04 PM
