Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-26-2007, 05:58 PM
blrmkr blrmkr is offline
Blows Constant Heat!! Please Help!
My 1991 Cutlass Supreme blows heat continuously. This happens regardless of the fan being on or off. The thermostat on the AC control unit does not adjust the temperature. The faster the car is moving, the more heat blows in. I’m assuming that there is a damper motor is stuck open. Or is there something else that could be causing the problem? Where is the motor located? Thank you for your help!
Old 08-26-2007, 06:21 PM
maxwedge maxwedge is offline
A990 racer
Re: Blows Constant Heat!! Please Help!
Welcome to AF, the issue with constant heat is either the dash temp control unit is bad or the temp door is stuck in the heat position, not advising guess work here but the dash units were prone to failure, check the temp door first.
Old 08-26-2007, 07:17 PM
Thank you for your help! I'm assuming that it is temp door because heat does not blow in when the car is not moving. Where is the door? Is it under the glove box? Thanks again!
