Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 01-21-2012, 11:49 PM   #1
Psiegrist1
2 different 98 Lumina transmission quirks
I'm new to this site so here goes:
I use this car on a rural mail route.
1. I start the engine and place it in drive and start to accelerate normally. Instead of rolling forward the engine will rev for a second and then all of a sudden jerk into drive. Guess what I'm trying to say is that it doesn't go into gear immediately. This only happens occasionally when the car has been shut off briefly, like when I stop to run a package up to someones door and return.
2. When I go up a slight incline with the torque converter locked the engine bogs down at little and when I ease UP on the accelerator it will downshift. However the transmission downshifts normally if I press down hard enough on the gas.
It's been doing this for quite some time and doesn't seem to be getting any worse. I had the trans serviced about 20,000 miles back too. Has anybody else had any of these things happen?
Thanks in advance,
Pat
Psiegrist1 is offline   Reply With Quote
Old 01-22-2012, 03:14 AM   #2
Bearwulf
Bearwulf's Avatar
Re: 2 different 98 Lumina transmission quirks
Which trans. does it have?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Bearwulf is offline   Reply With Quote
Old 01-22-2012, 04:05 PM   #3
jamesslcx
Psiegrist1, start with the basics have you made sure the tranny fluid is full?
jamesslcx is offline   Reply With Quote
Old 01-22-2012, 04:12 PM   #4
Psiegrist1
Yes the fluid is full. The transmission is the4T60-E.
Old 01-22-2012, 05:31 PM   #5
jamesslcx
Might be more than one problem. Check engine light ever come on?Doe it do this when engine is cold? Is the idle speed low? The hesitation could be caused by a sensor.
Old 01-23-2012, 03:59 PM   #6
maxwedge
A990 racer
If it is full all the not related external sources for this problem are irrevelent, it is an internal issue.
maxwedge is offline   Reply With Quote
Old 01-24-2012, 01:59 PM   #7
jamesslcx
Maxwedge there are external elements that effect the transmission performance besides level of fluid. My 1998 is slow to engage when put in gear, yes it's probably an internal problem but I feel my low idle speed doesn't help because if I increase throttle up to 900 rpm it engages faster. Also op said he had a bog at certain times.
1992 Bravada Can I use a different transmission? captainchuckit Bravada 2 03-31-2010 05:27 PM
Can all metro transmission interchange? Are there different Gearings? Idaho_Mechanic1984 Metro 6 10-19-2009 06:14 AM
96 lumina transmission help!!!!!! bigfry Lumina 8 02-04-2004 05:02 PM
1992 Lumina Transmission A&A Lumina 1 12-05-2003 11:24 AM
96 Lumina - Transmission Computer Chip?? pjfranco Lumina 1 10-20-2003 08:43 PM
