Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-16-2012, 09:26 AM
moif moif is offline
engine temp indicator shows overtemp,no other signs.
My engine temp indicator shows overheat to the red line, however when I stop the car I can put my hand on the radiator cap and leave it there. No signs of any leaks anywhere. The top radiator hose on the drivers side is hot. Engine runs fine. Oil on dipstick clean. I can`t find anything to back up my temp indication. Can anyone suggest what else I can look for? `87 chev caprice classic brougm ls 5.o liter. Thanks much.
Old 01-16-2012, 01:48 PM
j cAT j cAT is offline
Re: engine temp indicator shows overtemp,no other signs.
when first starting is it reading high ? if so the sender wire may be shorted to ground . low resistance will give a high temp reading.
when cold remove radiator cap. see if the coolant is flowing , rev engine see if you get good flow. see if the radiator tubes are clear and free from scale. no flow thermostat or the pump ...check belts.
see if you have bubbles in the coolant . this would indicate a head gasket. water pump pumps water not air ..any exhaust gases in the coolant the pump is useless..
corroded radiator exterior grill will also cause this high reading.
did this suddenly occur ? if so my guess the thermostat or sensor issues.
engine temp guage showing lil cool jbjslambert LeSabre 2 12-22-2008 02:54 AM
Car show pics and other project car pics. 56k no no vanilla gorilla Off-Topic 23 12-06-2008 09:39 PM
No HEAT and LOW engine temp solved!!! Gebo Trans Sport 2 02-16-2008 04:41 PM
No engine temp or oil pressure in 93 with 3.3 engone RickGary Grand AM 1 04-05-2006 07:54 AM
Engine Temp./No Heat ???? murfthesmurph Intrigue 8 02-22-2006 12:56 PM
