Old 01-15-2012, 11:21 AM
farns farns is offline
Power door lock won't open reliably
Good morning gang,
So far I have been blessed by your wisdom to help me through a number of significant engine issues with my 2002 Windstar. Now that it's running like it should, I need to address the less critical issues.
On the driver side of the car, the sliding door has an issue. The motor or servo or whatever it is that drives the door locking mechanism, is failing. Hasn't worked properly in like 2 years. It's been a mild annoyance, but in recent months it's gotten much worse.
When you unlock the doors, it pops up, but doesn't engage and stay there. It drops right back down to the locked position. So you have to play a timing game... one hand on the clicker, one hand on the handle. Click and pull with the right timing, to catch the door lock in the up position before it falls back down.
Well now it's not even reaching that point many times, and I'm worried that we're putting massive wear and tear on the other units in the car (pressing the unlock button 12 times to unlock it once), and also that in my rage I'm going to rip the door handle off the car!
I'm looking for some good instructions on how to take apart the door properly to get access to the motor or whatever it is. Is it something Autozone will carry or do I need to get it from a dealership? Is it something you'd get from a junkyard? Any advice you've got I'd love to get my hands on. Thanks!
Farns
Old 01-15-2012, 11:29 AM
Re: Power door lock won't open reliably
Sorry, I posted this before checking Autozone...
I'm guessing this is what I'm after, but I'm not sure:
http://www.autozone.com/autozone/par...115631_0_91487
It says "manual sliding doors" which I have... but then in the notes it says "cargo door". Is that the rear lift gate door? Or would the side doors be considered cargo doors?
Looks like I have to order it. Based on my description, do you guys think this might be the part that is failing?
Farns
Old 01-15-2012, 12:51 PM
aleekat aleekat is offline
Not sure if that is your problem, but I would check Rockauto.com prices. And I'm pretty sure that the side slider and rear are both considered cargo doors.
Old 01-21-2012, 03:14 PM
Searles Lewis Searles Lewis is offline
Smile Re: Power door lock won't open reliably
Farns
I've replaced one of these already. They are very easy to do, and yes this is the part.
I took mine off a wrecked Ford 150 at a junk yard. Paid ten or 15$ for it.
This part wears down on a lot of Windstars, and I had the same problem, and also it unlocking and locking after locking the door and walking away from it. You described the problem to a "T", this ought to fix it.
03 Optima Door Won't Open cmbsound Optima | Magentis | Lotze 1 09-30-2009 10:34 PM
01 Venture Power Door Locks Won't Lock honestdon Venture 2 10-16-2006 07:56 AM
'93 Taurus door locks won't open rrakoski Taurus | Taurus Wagon 6 08-31-2006 11:54 PM
Remote control front door locks won't open pizzaman2004 LeSabre 1 05-29-2004 09:33 PM
