Old 01-13-2012, 07:17 AM
Crazace Crazace is offline
ABS, Traction Control & Stability Control Lights
I have a 2008 Gran Prix GXP with 50k on it. It seems when it rains or snows the ABS, Traction Control & Stability Control messages popup on the screen saying the need service. When this happens they all stop working, but when its dry out they work fine. Where should I start looking for a loose connection at? Or what could it be?
Thanks!
Old 01-13-2012, 08:23 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: ABS, Traction Control & Stability Control Lights
First thing to do is to see what code(s)are stored. You can do a visual of the connectors at each speed sensor and check for water intrusion, and check for any obvious damage on the sensor harnesses.
Old 01-15-2012, 10:46 AM
rickisrad rickisrad is offline
check for a damaged or missing rubber bushing/seal at one of the bearing connectors. If they have been unplugged in the past the part may have fallen out. If it did the connector will move around too much or get wet and set the lights off.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 01-21-2012, 11:28 AM
The dealer scanned it and said it both front hubs are bad. Code C00400, and also the front right outer tie rod is going bad. They wanted $850 for this.
Old 01-21-2012, 11:43 AM
gmtech1's Avatar
If the problem occurs only when it rains of when wet, you have a problem with the harnesses going to the speed sensors. C0040 is set for the r/f sensor circut. Just because there is a sensor code, does not mean the sensor itself needs replaced. The harnesses are about 70-75.00 each. One way to check (although not fool proof) is to have the car running, in park, and preferably when conditions are set for the light to come on(wet), the turn the steering lock to lock and see if the light comes on. This will flex the harnesses, and if one is broken it will set the light.
Still, at 150.00 (or less) for both sides, thats alot less than 850.00!
You may be able to find the harnesses cheaper online. 70-75.00 is OEM parts.
Old 01-23-2012, 01:26 PM
We called the dealer back. They tested both sensors and individually. When I drove to work this morning it was raining and I turned the wheel lock to lock and it didn't short it. It only seems to happen when I'm going over snow, or there is blowing snow. With the tie rod should I just replace to other side too if my mechanic is going to be right there if that hub is bad?
Old 01-23-2012, 01:41 PM
gmtech1's Avatar
May as well replace both tie rods. That way you won't be wondering if the other one is getting loose.
ABS Traction control Module (HELP) ohio45344 Park Avenue 3 01-03-2011 09:53 AM
02 Rendezvous - ABS/Traction Control Issue RGrizzzz Rendezvous 2 11-25-2009 04:04 PM
01-Grand Caravan NO ac/heat, radio, PW & Wipers & ABS, Park Brk & trac off lights on backosjr Caravan | Voyager 2 08-05-2006 12:23 PM
what's cheapest car with nav, curtain airbags & stability control? zmre2b9 Car Comparisons 1 05-06-2005 02:30 AM
Need ECu, ABS, Cruise Control, and stability control help 96HondaCivic Let's get Technical! 0 12-06-2004 05:34 PM
