Old 01-09-2012, 09:42 PM
Pugnuts Pugnuts is offline
How to copy a wheel pattern
I need to build this wheel wonder if anybody has any good ideas on how to copy the pattern onto styrene sheet. I'm pretty comfortable going from there but am having problems getting a symmetrical pattern at 1/24th. I've done all the searches but can't find anything on this critical step.
Any ideas greatly appreciated . Don
Old 01-10-2012, 04:55 AM
jaykay640 jaykay640 is offline
Re: How to copy a wheel pattern
Best solution for a template would be to draw it in a graphics software ( Illustrator, Freehand, Corel Draw... even Photoshop should be o.k. for that) or CAD and print it out to stick it on the styrene sheet for cutting.
Old 01-10-2012, 05:18 PM
Helico's Avatar
Helico Helico is offline
The other solution is to find a similar wheel, modify it and use it as a master for casting. I think Tamiya NSX rim looks pretty close to what you want.
Old 01-14-2012, 12:19 PM
Foxerjr's Avatar
Foxerjr Foxerjr is offline
You might try just printing the image of the wheel at the correct scale and using that to apply to the styrene sheet to carve out.
Old 01-15-2012, 11:10 AM
gasdriverca's Avatar
gasdriverca gasdriverca is offline
Send a message via Yahoo to gasdriverca
I have the same issue as you not the same wheel though,but Im going to use a wheel from a similar kit to that i require & cut it down then use styrene sheet to make the plate(green painted part) around the edge & do a master from that.
my other problem is getting the tire too but i think i'll also make the tire & rim all in one or something
Uploaded with ImageShack.us
Projects on the bench:
Scania 124 Push Axle with Scratch built Curtainside Trailer
Opel Calibra V6 DTM (Reuter)
Panasonic Toyota TF102 (Mcnish)
Old 01-20-2012, 10:58 AM
Thank You, everybody. Appreciate the help.
Foxerjr - I did try that at first but will need to get a higher resolution and maybe a better printing too? I used a laserjet but I think I would need something that will give a finer print to be more accurate.
Helico - Thanks for the tip. That's a great shortcut because I was getting fed up looking at hundreds of wheels that weren't even close.
Jaykay - Good to know although I was trying to avoid the time it took to learn some of these. Might have to sweet talk my wife.. she has all those on her machine.
Gasdriver - let me know how you are doing. PM direct ? You might be better off using some tube instead of sheet for that rim.
Thanks
Don
Windstar wheel bolt pattern olopezm Windstar 1 08-09-2010 07:31 PM
How much would replacing/fixing leaking wheel cylinders cost? mrichards28 Lumina 2 06-22-2010 06:09 PM
lug pattern palmer6691 C/K 1 10-24-2009 10:27 PM
89 bronco wheel pattern? 89BroncoII Bronco 0 08-12-2007 10:43 PM
