Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 01-07-2012, 01:27 PM
juno juno is offline
Question Fuse Panel Box Blew Up!!!!
The pulse (+) side of alternator supply line melted my Fuse Box/top of battery. I took some picks for every one to see . . . What do you think could cause this to happen
you can see the wire insulation distorted from the heat
I am afraid to get a new box only for it to melt like this again . . . .
Old 01-07-2012, 08:54 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Fuse Panel Box Blew Up!!!!
There is a severe electrical short in that wire that got burned-off. Either the wire, a connector or the alternator is defective.
I would first suspect that wire is shorting -out to ground either by a defective terminal or damaged insulation. So start tracing that wire and correct the short beofore replacing the fuse box.
Wiring to a fuse or fuse box henrymv Accord/TSX/Accord Hybrid 8 10-07-2004 01:09 PM
Fuse, fuse box problems jafowler49 Camaro Discussions 2 11-27-2003 11:33 PM
Power lead to extra blade fuse in main fuse box bufpilot Odyssey 0 11-25-2003 10:25 AM
Radiator fan fuse has NO power under hood fuse box! Hybrid93Hatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-20-2003 06:25 AM
2000 Jetta fuse box? I think tail light fuse is blown... PSORC1 '97 - '03 0 10-12-2002 06:23 PM
