Old 01-02-2012, 05:51 PM
tken35 tken35 is offline
1995 GMC K1500 4x4 P/U - Heat
I just checked the temperature coming out of the vent after running the truck for a good 45 minutes on the road and the hottest it got was about 82 degrees. Am I correct that this seems kind of low? Also, I noticed that the compressor seems to cycle on and off intermittently, is this normal? The truck has 100,000+ and is not used very frequently, but I did change the coolant this past summer.
Thank you in advance!
Old 01-02-2012, 06:07 PM
777stickman 777stickman is offline
Re: 1995 GMC K1500 4x4 P/U - Heat
Check both heater hoses going to the firewall. If they're both hot then the core is ok. If one's cooler then the core is plugged.
Next is the temp control door. Not sure if your '95 has vac controls or electric.
A/C should only cycle when an A/C selection is made or DeFrost is selected.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
tken35 (01-02-2012)
Old 01-02-2012, 08:00 PM
Well I just ran the truck for about half 1/2 hour and the upper radiator hose is slightly warm, the lower radiator hose is ice cold, and both heater hoses going to the firewall feel almost as warm as the upper radiator hose (but that isn't saying much). With regards to the temp control door, we did replace the actuator a couple of weeks ago and the defrost, vent, and floor are now working; however, I do notice that the air blowing out of the defrost is not even.
What should be my next step?
Old 01-02-2012, 08:57 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Might be time to replace the thermostat
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
The Following User Says Thank You to corning_d3 For This Useful Post:
tken35 (01-02-2012)
Old 01-02-2012, 10:00 PM
Can anyone explain the differences between thermostats? Some are 160 degrees fahrenheit, some are 180 degrees fahrenheit, while others are 195 degrees fahrenheit, which is best? The vehicle is 5.0L TBI 8cyl.
Old 01-03-2012, 10:27 AM
For your truck, the 195 is needed for the Electronic Engine Controls.
57 Chevy 210
tken35 (01-03-2012)
Old 01-03-2012, 12:31 PM
j cAT j cAT is offline
you can check the thermostat operation out of the vehicle. see if it works correctly a number of times in and out of a pot of boiling/near boiling water. use a thermometer. test new thermostat as well.
remove the heater hoses at the engine , both then flush out / and back flush out the heater core. not too much pressure. see what is drained out in the bucket.
If you do not flush the heater core at the coolant change, low heater temp is common...for some reason all the coolant debris collects there.
at about 30 deg f you should have 130-145 deg f air coming out the vents.. blower on mid range.
3 years ago I had a lifetime warrantee thermostat new start to fail after one year. the temp on the dash in warm weather would lockin at 190 deg f. when the temps dropped to 30deg f or lower it would take a long time to rise from 175 deg f to the 190 deg f..replacing the thermostat no delay and rises steady to 190 .
since you replaced air duct components most likely this is not the problem. I would however make sure you have no vacuum leaks . I believe much of your air duct controls is powered by vacuum. a leak will cause doors not to move ..
The Following User Says Thank You to j cAT For This Useful Post:
tken35 (01-03-2012)
Old 01-03-2012, 02:14 PM
Schurkey Schurkey is offline
Almost certainly the thermostat.
The temp control actuator won't change the functioning of the defrost/vent/floor air distribution. That's a different actuator, if my '88 is any guide.
Huh? I don't understand. (Unless you mean that there's somewhat more air flow directed to the driver's side than to the passenger side, which is normal)
I can't vouch for 30 degree F ambient air intake, but if you have ~70F air intake, the heater output temp should be within 25 degrees of the thermostat rating. My '88 is throwing 170+ degree output temps, 195 degree thermostat.
The 88--and I believe this applies to that whole generation of full-size trucks--uses three electric actuators (they look like a tiny Grand Piano) to move the doors. No vacuum.
When I had heater problems with the '88, it turned out to be a rotted foam gasket between heater inlet formed into the sheetmetal of the cab, and the plastic heater inlet/recirculation/fan motor box at the extreme right side of the cab interior. I knew that the engine was properly warming, though. Had a 205F thermostat in it for a couple of years trying to warm the cab before I figured out that foam gasket was degraded. (Looked like foam, until I touched it--and it turned to jelly.) Didn't seal worth beans, created a gigantic cold-air leak under the dash. Every similar foam gasket on the heater system was similarly degraded. I replaced with generic adhesive foam strip rolls sold in the local home-improvement store.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
The Following User Says Thank You to Schurkey For This Useful Post:
tken35 (01-03-2012)
Old 01-22-2012, 04:20 PM
Well, it turns out it was the thermostat afterall! I finally got around to installing it and I just measured the vent temp and it was around 142 degrees .
I hope my picture clarifies my previous comment about the air flow not being even coming out of the defrost: Is this normal?
Old 01-22-2012, 06:48 PM
thanks for posting the fix. 140 deg f sounds good.
tken35 (01-22-2012)
Old 01-22-2012, 06:50 PM
I believe it is normal that the middle provides little flow on the dash def vent.
tken35 (01-22-2012)
1995 gmc sierra 4x4 transmission Kierracheyanne Sierra 5 08-12-2011 04:32 PM
1995 GMC 2500 4x4 ECM? 1995gmcbroken General Discussion 0 08-13-2009 09:06 AM
97 GMC k1500 4x4 Problems!!! Help! DredRum C/K 6 10-30-2008 11:13 AM
1995 Gmc 1500 4x4 ricksz400 Sierra 1 01-15-2007 05:23 PM
1995 GMC 1500 4x4 front axle seal leak. steelydan Sierra 0 08-03-2004 12:21 AM
