Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-02-2012, 12:57 PM
bernie2112 bernie2112 is offline
2006 Montana SV6 air pump problem...
Greetings!
On my 2006 Montana we have an air pump that can be used for pumping up mattresses and bike tires and such. For some reason it turns on by itself and, since this is at 3 am, runs until the battery dies. I think I could just remove the fuse until I can get it fixed but I cannot figure out what fuse it runs from.
Or is there an easy way to disable the pump since we don't use it very much.
Thanks in advance.
Happy New Year!
Cheers,
Bernie
Old 01-04-2012, 01:41 PM
rkvons's Avatar
rkvons rkvons is offline
Re: 2006 Montana SV6 air pump problem...
This pump may also be used to level your vehicle when there is heavy stuff in the rear. There is a lever underneath that registers when the vehicle is being pushed down and starts the pump. It will keep pumping until it's level again. Perhaps there is an air leak in the lines to the air shocks or one of the shocks themselves.
Old 01-04-2012, 04:00 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Rkvons is correct, the same pump runs your electronic suspension. The fuse is in the instrument panel fuse box, fuse #15 should be 25A fuse.
Old 01-05-2012, 05:20 PM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: 2006 Montana SV6 air pump problem...
This is curious. The system won't run unless the ignition is in 'accessory' or in the 'on' position. Can't run on it's own, I don't think. If it does, that's news to me. If so, it could also be the rod that connects the load-leveler control box to the axle. Mine broke off one end and the system kept pumping until I looked like a wheel trans van going down the rod!
If I had my way, every GM car I ever owned would be a Chrysler!!!
Rear suspension noise 2006 Montana SV6 Dougydoug65 Montana/Montana SV6 21 10-11-2017 12:01 AM
2008 Montana SV6 - Windshield Wipers problem... Sycko Montana/Montana SV6 7 08-25-2010 07:16 PM
Adding factory remote start to 2006 Montana SV6 dmorlow Montana/Montana SV6 4 01-30-2010 04:17 PM
2006 montana sv6 pulsating lights robert1963ca Montana/Montana SV6 1 11-09-2009 10:47 PM
Program old keyfob 2006 Montana SV6??? dorlow Montana/Montana SV6 0 05-22-2009 08:19 PM
