Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-23-2007, 06:30 PM
Dougydoug65 Dougydoug65 is offline
Question Rear suspension noise 2006 Montana SV6
Everytime I hit a bump inthe raod the passenger rear sounds like I have no suspension. I have had it into a shop and they were not sure what it is. It acts like the shock is bad but I only have 36000 miles on the rig
Old 08-28-2007, 12:48 PM
jegjc jegjc is offline
Re: Rear suspension noise 2006 Montana SV6
For my part I have a 2002 with 68,000 kms and my chocks are to be change I guess.
I think to buy thoses with spring around to help for more confort in the back and change the front too.
Is your suspension on your van is an air suspension ?
Old 12-27-2011, 09:11 AM
kmacks27 kmacks27 is offline
Did u find out what the problem was? I have changed the air shocks but i still have the noise
Old 12-27-2011, 08:25 PM
Tech II Tech II is offline
Check the upper bushing on the rear knuckle.......should be no movement....will cause a clunk.....
Old 12-29-2011, 08:09 AM
On my sv6 I don't have the independent suspension on the rear end i have the single bar going across with the air shocks. I changed those out for new ones. Would you have anymore solutions?
Old 12-29-2011, 04:58 PM
Exactly what kind of noise? Does it happen over large or small bumps? Parking lot maneuvers?
Old 12-29-2011, 07:04 PM
Noise is hard to describe. Like a clanging sound drivers rear. I just looked under the car spare tire was tight and I tugged and pulled on everything while I had it jacked up. Nothing was loose.
Old 12-29-2011, 08:11 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Have had problems with the bushings where the mount bolts go through the axle and mount to frame. You probably will not see anything wrong with them, but that is likley the problem. The bushings are servicable.
Old 12-30-2011, 05:21 AM
Could you please help me on this link this is what i have under the van where would the bushing be? Thanks again for your help.
http://www.newgmparts.com/partlocato...layCatalogid=0
Old 12-30-2011, 10:10 AM
gmtech1's Avatar
Couldn't find it on that link, but I was using my phone so that may have been why. I did find it on rockauto.com, Moog part #k200343. They did not have a picture, but the description is correct. 10.00 for the part. Noises are very difficult to diag without hearing it myself, but I have run into several of these when I couldn't find anything else wrong. Hope this helps!
Ok, got on my laptop, that illustration does not show the bushing. They are located at the piviot points of the axle assy. GM does service them, you may need to look at a dealer parts catalog.
Old 12-30-2011, 10:41 AM
so do u think I should order 2 of those?
Old 12-30-2011, 11:06 AM
gmtech1's Avatar
If you're gonna do one, do them both.
The Following User Says Thank You to gmtech1 For This Useful Post:
kmacks27 (12-30-2011)
Old 04-24-2014, 11:53 PM
Bruicer Bruicer is offline
gmtech1,
I'm having the same problem did you ever hear if he got the clunking noise fixed i checked everything on my 05 Montana sv6 and i can't find anything wrong visually just a crack in the road is noisy could you please post a picture with what you are describing what you think it might be thanks Bruce
Old 04-25-2014, 10:02 AM
Can you recreate the noise by bouncing the rear end?
If no, apply ebrake, jack up one rear wheel at a time.....now grab wheel and try to rotate forward and backward quickly.....if you hear a clunk, it's the upper bushing in the knuckle assembly....
Old 04-25-2014, 11:35 AM
Could you please show me the part your talking about thanks
