Old 01-02-2012, 07:20 AM
gtmud gtmud is offline
94 Z28 engine shut down
I see that there are a lot of posts regarding this issue on the series I Optispark systems. So here is my question.. 94 Z28 38K 6spd. Starts right up and runs well, for about 15-20 minutes then will shut down( like the key was turned off) When this happens I have no signal to either the ignition module or to the injectors. This car was damaged by an indiot that flooded the dist. with coolant doing a flush. They replaced it with a Advance auto reman. This is when the trouble started. I did replace the I/M with an AC OEM Module, no change, verified all wiring from the computer to the Dist. and I/M. All checked out. I am thinking that the cheap reman unit is my problem and am looking to get the MSD Opti spark system to hopefully fix and to prevent this problem from happening again. I cannot retreive codes (94 won't flash CEL codes). Is there any other method of diag I could use to verify my suspicions before I spend $400+. Oh, there is not responce from the Tach either once the engine dies.
Old 01-02-2012, 11:02 AM
Tech II Tech II is offline
Re: 94 Z28 engine shut down
How long ago did this happen? If within a year, bring it back to them.....if they find the distributor at fault, they should replace it for you.....
Just about impossible to diagnose without a scan tool....
Old 01-02-2012, 11:28 AM
Thanks TechII,
I really don't want to waste time with Advance auto junk. I have had nothing but bad from them in the electronic dept. I have researched their remans and they are the A-1 Cardone reman units, the feed-back on their units is really bad. I have an Ford IDS touch-book with the Osciliscope function. Is there anyway that I could monitor the signal to see if its the dist. or the ECM?
91 Lumina 3.4 engine Engine Shut Down at Intersection comet240 Lumina 1 07-04-2007 08:40 AM
1989 Honda accornd engine shutting down DocVoodoo Let's get Technical! 1 11-07-2004 09:11 PM
Engines shuts down while driving millerc Lumina 6 07-17-2004 04:22 PM
engine shut down while driving. akulp Sierra 1 07-13-2004 10:57 PM
intermittent engine shut down/ starting georgenickas SC/SL/SW 1 12-14-2003 11:33 AM
