Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-01-2012, 05:08 PM
DonovanDavis DonovanDavis is offline
96 Eclipse RS-T 420a Clutch Problem
Hey guys I have a 96 eclipse rs-t thats having a few issues... I recently changed the clutch to a stage 2 kit with the throwout bering and flywheel(Bahnhof). A new tranny, New Clutch Slave/Master cylinder, Throwout bearing, and it is still makinng grinding noice like the car wants to go in gear but it dosent. It seens as if the clutch isnt ingaging all the way even after bleeding the lines multiple times. The clutch pedal has about 5 in's of play... then when you push it to the floor it has pressure but seems like it isnt enought to help with the clutch. Can anyone help?
Old 01-01-2012, 10:19 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 96 Eclipse RS-T 420a Clutch Problem
Sounds like the clutch is not fully releasing. The clutch should only have about 1-2 inches of free play at the top of the pedal. After that it should start to push out the slave cylinder. If it has more free play then you probably have air in the line still. You can also measure the movement of the slave cylinder, If I remember right the slave needs to move about 0.350in to release the clutch. If you are not getting that much travel then you have air in the line, clutch pedal out of adjustment, or the rubber line needs to be replaced.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
96 Eclipse rs 2.0 non turbo Check Engine light donidavis Eclipse Problem Diagnosis 6 12-02-2010 08:39 AM
00 Eclipse GT (115k mi) Clutch Question Stock00ClipseGT Eclipse 2000+ 3 11-26-2010 02:39 PM
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
1998 mitsubishi eclipse rs flywheel question E. Frank Engine, Transmission and Drivetrain 4 08-22-2009 11:38 AM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
