Old 12-30-2011, 02:24 PM
amuenp amuenp is offline
Powersteering fluid ran out, now squeeks..
Hello All,
A week ago my power-steering started squeaking so checked the fluid level and it was completely gone. I filled it back up and moved the wheel all left all right over and over.. thought it was fixed. However, as I drove for a bit it started to slightly squeak again as I turn. If I move it back and forth a few times it will stop for a bit. Is this something I need to have bled or will it eventually burp itself?
Also, will this damage anything if I don't fix it right away?
Thanks for any help!
Old 12-30-2011, 04:39 PM
Scrapper Scrapper is offline
AF Premium User
Re: Powersteering fluid ran out, now squeeks..
Originally Posted by amuenp View Post
Hello All,
keep moving sterring wheel back and forth may have air still in it? also may be the pump itself since it ran dry or belt.
good luck.......
Old 12-30-2011, 10:18 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
good luck.......
Yup, just turn it full lock left to full lock right and back again a few times. It may be best to do this while rolling forward slowly.
Finally, I have found (at least with Ford and GM pumps) if the run dry for a while they become damaged internally and will subsequently be noisy.
Old 01-01-2012, 12:57 AM
GuyWithCavalier's Avatar
GuyWithCavalier GuyWithCavalier is offline
Red face Re: Powersteering fluid ran out, now squeeks..
Hello All,
If the fluid left at one point, you should be concerned as to why,
and where it went!
Obviously it will drain again if you don't find the cause.
Seems like that is more important than it being noisey...
Why wait until it is empty again?
Maybe more damage would ensue, never minding safety hazards..
Always Listen to the Experts:
They'll tell you what you CAN'T do, and why.
Then go ahead and do it.
Thats how we got manned flight...
Ran out of gas, now the problems begin...Help! JTech Aurora 3 09-23-2004 12:19 PM
97 camaro 3.8 ran out of gas...now engine light comes on sipote Camaro Discussions 8 07-01-2004 09:59 AM
'86 IROC ran out of gas, now won't crank. Piritu Camaro Discussions 7 11-13-2003 12:11 AM
Dang! Ran over something and all my Transmission Fluid leaked out! green96accord Accord/TSX/Accord Hybrid 2 03-13-2003 06:32 PM
Ran out of Gas now Engine Won't Start rob17 Engineering/ Technical 1 08-11-2002 12:18 PM
Tags
fluid , issue , powersteering
