Old 11-10-2003, 10:58 PM
Piritu Piritu is offline
Question '86 IROC ran out of gas, now won't crank.
We just purchased an '86 Camaro IROC Z-28 with a broken fuel gauge. It's been running fine, but we didn't know how much gas it had in it, and today it ran out. We filled it back up, but now it won't crank. It doesn't smell flooded; in fact it seems like it's getting no gas at all. Could the fuel delivery system have been affected by it running dry?
Old 11-11-2003, 09:56 AM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Re: '86 IROC ran out of gas, now won't crank.
It should still crank with or without the gas. I think your problem is elsewhere. Does it have any power at all? Like does the stereo work. If not, you may want to check the Batterie(maybe get a new one).
Just for the Stroke of it...
Old 11-11-2003, 04:35 PM
icebrew405 icebrew405 is offline
Send a message via AIM to icebrew405
well from my experience, usually when you run your car dry out of gas, its definatly not good for the fuel pump, and on older cars itll usually damage them to were they wont work. As far as your car not cranking over, check the battery connections and check with a check lite were theres power. Maby theres a short somwere too ya never know.
Old 11-11-2003, 05:13 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Once you get it cranking and it still doesn't start. I would change the fuel pump. Most GM Fuel Injected cars out of the 80's have fuel pumps that die.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 11-11-2003, 05:19 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Are you shure that you ran out of gas mabye something eletrical happend and your feul pump is not getting power. Just an idea.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 11-12-2003, 12:11 AM
StingRay_68 StingRay_68 is offline
I think he means it won't turn over on it's own. If it's carbureted, pour a little gas into the carb to get the juices flowing a bit. If it's injected, then it's probably your fuel pump.
Old 11-12-2003, 07:38 PM
Hypsi87's Avatar
oh my bad...What can I say I drive a buick my vision must be going bad. (kinda like all of the other 70 year old people who drive them )
the pouring the gas down the carb will work for the TBI cars as well.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 11-12-2003, 11:11 PM
Thanks for the suggestions. It's a TPI, 305 and the problem does seem to be the in-tank fuel pump: With the ignition on, there's no 'sound' from the tank. Fuse is fine, so replacing the fuel pump seems to be the next logical step. Thanks for the help all.
