Old 06-28-2004, 08:55 AM
sipote sipote is offline
Angry 97 camaro 3.8 ran out of gas...now engine light comes on
My wife let the camaro run out of gas empty..after putting gas in it, and adding gas additive, the engine light comes on. could it be related to the car running out of gas??
thanks
Old 06-28-2004, 09:11 AM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
I honostly don't think so.
Unless their's air somewhere.
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: 97 camaro 3.8 ran out of gas...now engine light comes on
Running out of gas in a f-body is probably the worst thing that you can do to these cars. i wouldnt doubt that its related, im just not sure how it would be effected. run a scanner and see what code it throws...
*Better power-to-weight ratio than a C6 corvette*
Old 06-28-2004, 11:51 AM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
why is running out of gas the worst thing for an f-body i did the other day and its fine
Old 06-28-2004, 12:15 PM
well atleast the 4th gens, cause the fuel pumps can get damaged if you run em dry and then you have to pull the whole rear and tank to replace it. its an ugly mess. i guess its not really the WORST thing you could do, but from a "holy crap my car dont work and now i gotta fix it" stand point it sucks...
Old 06-28-2004, 12:27 PM
so maybe perhaps..my fuel pump could be damaged? but the car is running fine?
thanks
Old 06-28-2004, 01:50 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
maybe its running lean.. that would cause for an engine light
Old 06-29-2004, 11:39 PM
CALIROCZ28 CALIROCZ28 is offline
Similar Problem Plus more
The same thing happened to my wife. She let the car run out of gas ended up having to tow car home.
The car is a 1995 Camaro with the V6 3800 200 hp engine. I responded to where she broke down with a 5 gallon can of fuel. Replaced the filter, did a switch on the fuel relay, primed the fuel pump from the underhood connector, Sprayed gas into the Throttle body and the thing would not start. I towed it home about 4 blocks and spent the weekend getting it to start. I did a number of things and finally got it started late Sunday afternoon. I have a Tec l but it needs a new keypad. Most likely could have reset something with the tech l and saved myself about 20 hours of labor pulling stuff and putting it back. I have know clue what I did to finally get it to run but it finally fired up. I reset the PCM and you name it I checked it. Well ever since this incident the check engine light comes on and stays on even after I reset it.
The car runs terrible right now. I would really appreciate it if someone can help me with telling me what the problem could be. Here is what the car does. These symptoms are intermittent.. The car runs great on the freeway but really sucks gas now where before it got great milelage city and highway.
Whenever I pull out of a driveway such as at a gas station and the driveway is at a certain angle the car stalls but will start up after sveral cranks. Occasionally dies right after getting off the freeway when I come to a stop.
Cranking time is excessively long. When the car has been parked overnight or for several hours it fires up immediately on first turn of the key.
The gas milelage is worse than my '98 Z28 with the LS1. It compares more to a gas hog V8 maybe about 10 mpg city and 14 freeway.
I change the oil every 3000 miles and have always used Mobil 1 since day 1. The car has about 95k on it but 80% of the miles are freeway miles.
If none of you can help me with this I will send my tech 1 in to have them replace my broken keypad since that is the only way you can get one fixed. They will not sell you the parts. They will replace my keypad for $150.00 and send it back to me the whole thing taking about 4 weeks.
I have always fixed my own cars and taking it to someone else like the dealership is not an option unless it is for a recall to replace a transmission like they did shortly after buying the car. So if any of you Camaro Guru's have the answer to my problem I'll send you a 6 pack of your favorite beer or soda or water or cooler or your preference if it's within my price range. lol
Many thanks in advance to all who may help.
Joe
CALIROCZ228
Old 07-01-2004, 08:59 AM
UPDATE i had the codes read and it was talking about the map sensor and a O2 sensor on the back of the car..we are hoping those sensor were triggered with the car going empty on gas.
