Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 12-27-2011, 11:37 AM
fred jonson fred jonson is offline
My Fiero has some crazy idle problems
When I start my Fiero SE(v6) it idles just fine for 6-8 minutes then the RPM drops off and the car almost kills, after which the engine revs way up and slowly comes back down to almost killing. It does this for another 5 or so minutes until it shuts off completely. If I put the car in Gear it dies immediately. It looked like some sort of throttle position sensor was causing the problem, so I jammed a credit card in the mechanical part (to hold the throttle open). This would fix the idle problem for 30sec to a minute but then something else would click and the car would shut off. I am wondering if this is a sensor, computer, or some kind of other issue.
Old 12-27-2011, 05:02 PM
Tech II Tech II is offline
Re: My Fiero has some crazy idle problems
What year?
Check for codes?
check for vac leaks?
Famous for broken exhaust manifold bolts...
Old 05-14-2012, 01:00 PM
ryanusrey2012 ryanusrey2012 is offline
You could possibly take out and check the EGR valve for carbon build up and it also could be your IAC (idle air control) for problems if those are not the issues than it could be what Tech II said
I need some help with my 95' 3000gt.... RedHeadedDemon 3000GT/Stealth 2 06-04-2010 05:28 PM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
Bad Idle... Must be an idle motor problem ? Trueeclipse Eclipse Problem Diagnosis 0 05-25-2009 05:16 PM
crazy idle problem redtegb18b1 '96-'00 Civic 3 01-25-2005 08:26 PM
1991 Royale has accelration and idle problems qseal00 Eighty Eight 2 02-09-2004 08:34 PM
