Go Back   Automotive Forums Car Chat > Land Rover > Discovery | LR3 | LR4
Old 12-26-2011, 06:43 PM
Affordable Engine Affordable Engine is offline
Rebuilt Disco Engine Tips
I have a company called AffordableEngine.com that sells used engines and we recently had a long discussion with a very experienced Land Rover engine rebuilder about '00-'04 Discovery Engines. Here are the key parts of the discussion:
1. Use the newly designed timing cover for better oil circulation and pressure
2. Use the Land Rover oil filter because it has a "check valve" and your local oil change place won't have the right type.
3. Use 20/40 oil which again, you won't find at jiffy lube
4. Run premium fuel.
He said if you do all of these things you should be good to go...
2000 z71, 5.3 budget rebuild, any tips nthnkng33 General Discussion 2 07-20-2010 09:06 PM
New rebuilt, used engine, or repair RocketUSA Silhouette 6 10-11-2008 01:57 AM
Cold engine = stalls Hot engine = rough idle Dave01234 '97 - '03 2 02-19-2008 11:35 PM
Rebuilt Acura Engine seahorsef40 Classifieds 2 05-14-2006 04:47 PM
Racing/engine tips needed! 2kCivic_GSR Street Racing 21 01-13-2005 12:13 PM
