Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 01-11-2005, 09:11 AM
2kCivic_GSR's Avatar
2kCivic_GSR 2kCivic_GSR is offline
Unhappy Racing/engine tips needed!
I have a 2000 civic Ex, and i recently swapped a b18 c1 into it. I have i/h/e, fuel rail and regulator installed on it now. I was wondering if there may be a problem with my engine because when i raced the other night with several other cars. First and second gear seem to lagging real bad and not picking up speed like it should.My friends integra has the same engine mods as i do. and when he takes off he picks up speed off the start. so could it be and engine problem? i need to practice racing more? more engine mods?
Old 01-11-2005, 11:24 AM
Boosted1 Boosted1 is offline
As you undoubtedly know, B series engines require high revs to make their power. I had a Civic SiR (B16), and it came alive around 5500rpm. Do you find the car pulls much better once the VTEC kicks in? If not, then it could be a problem. Where did you get the engine from?
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 01-11-2005, 12:18 PM
Re: Racing/engine tips needed!
Yes it does pull alot better, but thats not until 3rd to 5th gear. 1st and 2nd seem to struggle more than it should when picking up speed. I got my engine from a Del Sol that was wrecked. It was a rear hit. thanks for replying
Old 01-11-2005, 02:17 PM
That is odd; I had a 2000 Civic SiR (Canada)...it had 160hp and 111lb/ft torque. Even in first, once it hit about 5500rpm, it would really take off and pull strong until 8200rpm where it cut out. Second was just as strong; I could downshift at like 80km/h and chirp the tires and really take off. The car wasn't downright fast, but very quick and respectable. Yours should be similar, except obviously faster. You should take it to a track sometime or run with a G-Tech meter; at the very least, run against a car off the line you know you SHOULD be able to beat, and that should give you an idea of how it is actually performing. Hopefully you get it figured out, all the best.
Ryan
Old 01-11-2005, 02:22 PM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
Check and see if it's throwing any codes...it's the car sputtering or anything or is it just slow
Old 01-11-2005, 02:26 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Re: Racing/engine tips needed!
I agree.
It could be running rich or there could be some thing wrong with your spark. I could be a number of things.
Old 01-11-2005, 03:33 PM
CassiesMan's Avatar
CassiesMan CassiesMan is offline
AF Vendor
Send a message via AIM to CassiesMan
Re: Re: Re: Racing/engine tips needed!
Originally Posted by Polygon
I agree.
Could ya now?
*My computer hates me and wont let me aee or post smiles, but insert appropriate smiley here*
2006 Redline Red Nissan 350Z Base
K&N|Falken
I am just that JDM tight, yo.
Old 01-11-2005, 03:37 PM
Polygon's Avatar
The Red Baron
Re: Re: Re: Re: Racing/engine tips needed!
Originally Posted by CassiesMan
Could ya now?
I have no idea what you're talking about?!?
*insert evil laugh*
Old 01-11-2005, 03:46 PM
CassiesMan's Avatar
AF Vendor
You could "still be a number of things"
K&N|Falken
Old 01-11-2005, 04:02 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Well you put a new fuel rail and pressure regulator in, it could be you need higher flowing injectors. That's the problem with just throwing performance parts on, just cause a magazine says they will work with that engine doesn't mean that they will work properly without adding more and more stuff to compensate for the changes they will make.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 01-11-2005, 04:10 PM
CivRacer95's Avatar
CivRacer95 CivRacer95 is offline
srs biznis
Send a message via AIM to CivRacer95
Late...
AF Guidelines. Read and play nicely :
Just Click Here!
Old 01-11-2005, 07:35 PM
Yamahapower Yamahapower is offline
Send a message via AIM to Yamahapower
So you swapped the engine out of your del sol? The engine prolly runs fine but now its under more weight, thats why it feels slower at lower speeds and faster once you get moving.
2000 I30t, all stock and babied....
Old 01-11-2005, 07:45 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
No No... he got the B18c1 out of a wrecked Del Sol.
He put the motor into a 2000 Civic Ex...
I don't think he owned the Del Sol, so I don't think he'd know how hard it'd pull in that little car.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 01-11-2005, 08:19 PM
Oh...well its still not a torquey motor, you just gotta rev it out to get it going thats the kind of motor it is.
Old 01-11-2005, 11:46 PM
streetrcr45's Avatar
streetrcr45 streetrcr45 is offline
the difference in weight between the two cars is around 200 lbs...so Yamahapower could be right about the weight difference, but like redneck said..
and i quote "I could be a number of problems"
DIE TRYIN
FORGIVE BUT NEVER FORGET
