Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 12-24-2011, 03:09 PM
borninabarn borninabarn is offline
Exclamation 02 626 2.0 auto no start what sends the signal to turn the fuel pump on??
On my Mothers 2002 2.0 626 automatic 97,000 miles the car will start sometimes if you turn the key back and forth fast many times and then you hear the fuel pump humming.It wont start if you dont hear the pump turn on.I just replaced the ignition switch thing that was it but it wasnt.I have replaced the fuel pump relay and the fuses all check out.
What sends the signal on these cars to turn the fuel pump on??? or is it a faulty fuel pump that is on its last days? I looked under the rear seat for a fuel pump access but there wasnt one?Do you have to pull the tank on this year to put a fuel pump in it?If that is what I should do?I cant keep throwing parts at it hoping it works everytime.I thank anyone that can help in advance!
Old 08-31-2012, 10:14 AM
Re: 02 626 2.0 auto no start what sends the signal to turn the fuel pump on??
UPDATE from this old post.It was the Fuel pump!
Mystique 2.0 auto no spark/fuel ideas?? jeremy06 Mystique 2 02-07-2010 06:14 PM
Whats the best way to change fuel pump on my 98 crew cab 3500 Dually? flash12 C/K 8 09-29-2008 08:56 AM
info on Mazdaspeed 626 2.0 turbo swap into MX3 red MX-3 MX-3 1 10-26-2005 08:17 AM
'96 jetta 2.0 No start condition, engine doesn't turn over hub999 '91 - '96 2 08-29-2005 06:59 AM
what is the firing order for a '93 626 2.0 4cyl crazybob 626/Capella/Capella Wagon 3 06-02-2005 11:25 PM
