Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 12-13-2003, 01:10 PM
crazybob crazybob is offline
Unhappy what is the firing order for a '93 626 2.0 4cyl
I recently took my 626 to have a tune up,and a timing belt put on.I also had to fuel system cleaned.The next day she started smoking like cheech and chong (white smoke).So I took her back and my mechanic could not find anything wrong.He checked the plugs and gasket.I left to pick up some parts(distributor cap and rotar) to try and fix a slight miss,most noticeable at stops.After taking the old distributor off and old rotar off I replaced with new ones.I got in to start but she will not turn over.I dont know if the wires are right .Does anyone know the firing order for '93 626 2.0 4cyl.I need help ,I'm stranded . thnks bob
Old 01-10-2005, 04:45 PM
jchevier jchevier is offline
I also need to know the firing order for a 93 mazda 626 and which terminal on the distributor cap is for the #1 cylinder.
Old 02-10-2005, 10:22 PM
cswor cswor is offline
the #1 cylinder is on the left (passenger side) and firing order is 1-3-4-2. since you asked about the distributor, i guess it is already off or no longer has the wires on it. if this is the case, you may be able to examine the cap and look for a raised letter. if it is there, this marks the #1 connector. if you don't find a raised letter, maybe someone else can help out.
Old 06-02-2005, 11:25 PM
TopSpeed2130 TopSpeed2130 is offline
firing order 1342 and on the distributer it is 1-4
2-3<-front of car
