Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-20-2011, 12:41 AM
wagslick wagslick is offline
Thermostat going up and down
We have a 2003 Malibu v6. My wife pulled over and called because the overheating light came on and the temp gauge was pegged all the way. She started the car a few min later and everything was fine again. I drove it just the other day and watched the temperature go from no temperature (gauge all the way to the bottom) to hot (all the way to overheating) in under a minute. I kept driving and the temp went to normal then back to hot again all within about 2 minutes. Is this a cooling issue or a thermostat issue? My father in law says replace the thermostat and it'll be good. Any ideas?
Old 12-20-2011, 01:59 AM
DeltaP DeltaP is offline
Re: Thermostat going up and down
Possible air in the system due to a very low coolant level.
Old 12-20-2011, 09:17 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
As stated above, check your coolant level. You may have a coolant leak. Were the cooling fans running? You say the gauge was pegged hot? It's also possible you have a bad temp sensor. Yes, a thermostat is also possible.
Old 12-20-2011, 10:31 AM
I agree.
Old 12-20-2011, 05:41 PM
j cAT j cAT is offline
since this is always failing look for this . when in the overtemp range is the engine really overheated ? are the fans running ?
coolant should be a pink color . if its dark brown you may have sludge in the coolant from mixing dexcool with non gm approved dexcool spec.
when this occurs blockages cause this type of issue ....
Old 12-20-2011, 07:26 PM
Tech II Tech II is offline
Like the guys said, check the level first....
Old 01-01-2012, 03:20 PM
Had coolant flushed and filled. The temp gauge acted normal for a while.
Old 01-01-2012, 04:59 PM
did you have the sludge in the coolant/engine ? if so keep close watch on the coolant to get sludged up again. only use distilled water and dexcool ..try to keep it at 60 % dexcool to 40 % distilled water. you can go up to 70% dexcool for max protection .
Thermostat is going waving up and down during warm-up Donald91tbird Thunderbird 1 02-15-2006 02:36 PM
antenna not going up and down andyjs3589 Integra 4 01-30-2006 09:47 PM
Revs go up and down will cold!! acehardy Prelude 8 02-12-2005 02:42 PM
sun roof wont go down all the way and wont go up... triplerc Neon | Plymouth Neon 3 04-01-2004 09:33 PM
Tags
crazy , thermostat
