Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-13-2011, 06:37 PM
debsco731 debsco731 is offline
1997 Camry 2.2 surging
My husband and son just put an engine in my son'e 97 Camry 2.2. It ran great, but there was a leak in one of the injectors. They replaced the injector o rings, and now, when you crank it, it surges while it is running. It goes from normal idle to a very fast idle and back down to normal about every 3-5 seconds. Any one have any ideas on what could be causing this? Thanks for your help.
Old 12-13-2011, 07:08 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1997 Camry 2.2 surging
Check your EGR valve for heavy carbon deposits (clean if heavy deposits are found) and EGR valve diaphragm for proper/smooth function. Check the EGR vacuum modulator and VSV for EGR for proper function.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-13-2011, 08:17 PM
Just replaced the Egr valve and now it idles but its at a steady 2200 rpm and will not drop but you can give it gas and it will take the gas like it should. any other ideas?
Old 12-13-2011, 10:46 PM
Brian R.'s Avatar
Resident Chemist
See if the engine coolant temperature sensor is in spec, and has good connection to the harness, and the harness is good.
2006 Cobalt 2.2 ecotec engine replacement procedure needed dumb dummy Cobalt 3 06-26-2010 09:50 PM
Mazda 2.2 Blowing Oil? cnixon General Discussion 1 03-20-2009 06:13 PM
'99 Sonoma 2.2 2wd Flooding? Ronniet Problem Diagnosis 3 12-30-2008 10:09 AM
1997 Camry 2.2 with major problems debsco731 Camry/Camry Hybrid/Vista 2 12-14-2008 03:07 AM
94 Corsica 2.2 - surges.....HELP! tingland Corsica 1 10-29-2006 07:30 PM
