motor size ?
tell me what ven letter tells me the size of my c 10 chev truck 1969 230 or 250 ?
Re: motor size ?
Answer: You're not getting this information from the VIN.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: motor size ?
I don't think the 230 was used after 1966 so likely your 6 cylinder ( if an original stock engine ) is either a 250 or a 292 . The 250 motor mounts will be straight across from each other while the 292 mounts will be offset from each other . I'm sending a PM with additional info .
" Sometimes I grow so tired " |
Re: motor size ?
The info I'm finding looks like most identifiers are internal. If the pistons are flat topped with valve reliefs stamped in them, its a 230. If they have "D Shaped releifs its a 250. Also, the 230 has a 3.25" stroke where the 250 has a 3.50" stroke. Most of the parts seem interchangeble.
