Old 01-24-2004, 10:35 AM
Jap GTO Jap GTO is offline
Question Motor size and power
hey all, just wondering what is the difference between the DOHC and SOHC motor? what year/model are they in and what is the horse power on the cars 91-99?
thanks
Cam
Old 01-24-2004, 03:09 PM
Igovert500's Avatar
blue + red light magnet
Re: Motor size and power
DOHC = dual overhead cams
SOHC = single overhead cam
as for all the specs, check out http://www.team3s.com/FAQ-Specs1.htm
it has all the models listed with their engines, hp, and torque
Old 01-24-2004, 03:25 PM
Igovert500's Avatar
The cams or camshafts are what control the valves in your engine. Overhead cams means that the camshaft(s) is above the head and the distance it has to push the rods to activate the valves is shorter. Basically, this means less movement of valvetrain parts which allows for quicker response and higher engine speeds. A SOHC engine only has one camshaft with enough lobes to operate both the intake and exhaust valves. The DOHC is more advanced with the two camshafts, one for the intake valves and one for the exhaust.
Old 01-25-2004, 02:46 PM
alright thanks a lot bro
Power Window Failing trobious Outlander 3 01-05-2011 04:28 PM
02 Town and Country Lmt, FWD - Clunking from front end and power door problems confused81 Caravan | Voyager 12 08-06-2010 10:19 PM
motors swaps for power and play room viper32435 SC/SL/SW 1 05-09-2010 04:19 PM
Lock, and power seat problems!!!! Jefferscene Taurus | Taurus Wagon 12 01-20-2010 02:00 PM
Size of drain plug for motor oil and bolts for transmission pan jsnowbordr47 Suburban 1 05-11-2008 09:44 PM
