Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 12-10-2011, 04:07 PM
oak2001raid oak2001raid is offline
99 Bravada wont start
Cranks fine, good spark, 62psi fuel pressure at fuel rail, new plugs, wires.
When I changed the plugs most of them were soaked with gas. If you pump the fuel pedal it acts like it wants to start but won't. Any help would be appreciated.
Old 12-11-2011, 02:27 PM
diesel1962 diesel1962 is offline
Re: 99 Bravada wont start
What engine is in your vehicle? Diesel1962.....
Old 12-11-2011, 04:27 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Is the Check Engine light on?
Does the fuel pressure stay up for a coupla minutes?
Remove the air inlet cover on the throttle body.
Pour a tablespoon of gasoline down the throttle body.
Replace the air inlet cover.
Try to start the engine.
What did it do?
Old 12-12-2011, 09:35 AM
poured the gas into the throttle body, it didn't hit or anything.
Old 12-12-2011, 09:36 AM
I pulled a couple of plug wires one at a time, then I put another plug into the wire. It seems like it is firing fine.
Old 12-12-2011, 11:23 AM
maxwedge maxwedge is offline
A990 racer
If you have " good" spark and fuel it should start, someytthing is amiss of course, try a quick shot of starting fluid, post back.
Old 12-21-2011, 12:57 AM
tried starting fluid, still nothing just cranks and cranks
Old 12-21-2011, 03:22 PM
billn2 billn2 is offline
Did it run before you changed the plugs and wires? Not trying to offend you just curious. If you're getting fuel and spark you may have a problem with the fuel injection or maybe it's flooded some how. You said it acts like it wants to start when you pump the gas, try holding the gas down while you try to start it. If it's flooded this will give you more air and should stop the flow of gas until it starts and you let your foot off the gas.
Old 12-21-2011, 04:06 PM
DeltaP DeltaP is offline
I agree. Just what I was thinkin. Pedal to the metal and crank the crap outta it, 'clear flood mode'. Worth a shot.
Old 12-21-2011, 04:28 PM
A990 racer
Or pull a plug and see if it is wet.
Old 12-21-2011, 07:56 PM
Yes it did run before I changed them, It ran for about two days after I changed them, the battery was low and I pulled it into the backyard and put the battery charger on it overnight. I did try the pedal to the metal thing but it just cranks and cranks. I pulled one of the plugs and it was soaked it gas.. I appreciate your help.
Old 12-21-2011, 07:59 PM
You don't think it might have anything to do with passlock do you? When it was running, the security light would flash after I turned the motor off and continue flashing for about ten minutes. Even after I removed the keys and shut the door. It ran fine though.
Old 12-21-2011, 08:23 PM
AF - Advisor
Wet with gasoline/you might smell the plugs to be sure, means there's ample fuel.
A spark may be present but it may quit firing under compression when the ignition coil starts failing.
Cylinder misfire at WOT & high rpm usually indicates a failing ignition coil.
Did you ever get that with your A990 426 Max Wedge race car Maxwedge?
Was this condition present prior to the present problem oak2001raid?
Old 12-21-2011, 08:30 PM
yes it was wet with gas, I did smell it. It was missing a little bit before I changed the plugs, that's why I changed them. It did run fine for a day or two before this happened. I didn't put AC Delco plugs in tho. I am gonna pick up a set of those tomorrow and try that.
Old 12-22-2011, 07:52 AM
A990 racer
Smile Re: 99 Bravada wont start
Chris I ran the high performance Mopar electronic ign, and used a Multispark as a back up, took about 2 minutes to wire up and switch systems, there was not et or mph difference between either ignition systems.. Side gapped A22 Autolites and never had a misfire shifting at 7k rpm's.
1996 Bravada wont start kelvin424 Problem Diagnosis 3 03-30-2009 08:38 AM
93 bravada wont start. help! olds1 Problem Diagnosis 4 03-10-2008 11:18 AM
94 bravada wont start booboosissy Problem Diagnosis 4 12-06-2007 05:33 PM
92 Olds Bravada - Wont start 92oldsbravada Problem Diagnosis 2 12-05-2007 09:16 AM
94 Bravada wont start now thebox_is_here Bravada 24 06-01-2006 07:52 AM
