Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-10-2011, 03:47 PM
rotax30 rotax30 is offline
engine bogges
95 ram engine codes#24-tps,#32-egr solenoid,#34-speed control solenoid.What the heck is going on?
Old 12-11-2011, 04:44 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: engine bogges
24 Throttle position sensor voltage too high or low.
TPS sensor is out of normal range.
32 EGR Solenoid circuit Short or open in the EGR solenoid circuit.
Check for loose, broken, or shorted wire in the EGR valve wiring and connectors. Possible air fuel ratio imbalance not detected during diagnosis.
34 IAC/Speed control circuit or speed control switch always low or high.
An open or short in the speed control vacuum or vent circuits. Speed control switch input above or below normal range.
These could be affected by poor battery voltage. Are you seeing at least 12.56 volts on the battery with a volt meter?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Engine boggs out. Rick's69 Type 1 3 11-24-2005 04:38 PM
Engine boggs down on acceleration SKSuser Accord/TSX/Accord Hybrid 0 09-12-2005 05:41 PM
engine boggs at 3500 rxv8wannabe RX-7 6 07-09-2005 10:56 AM
Engine boggs and hesitates when accelerating from stop tuanphan@yahoo Engine 3 07-12-2004 11:34 AM
Engine boggs at 3500 rpm during shift Jeaunz General Discussion 1 03-16-2004 12:20 AM
