Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 11-14-2005, 04:42 PM
Rick's69's Avatar
Rick's69 Rick's69 is offline
Send a message via AIM to Rick's69
Engine boggs out.
I am trying to tune my double barrel 40 webber to my 1835cc bug. It boggs out so should i advance timing? lean outthe carb? add more fuel? or put timing to stock?
The timing is advance just a little about 12 degrees above TDC and i dont know how to get the most power out of it
Another thing. when my engine is cold in the morning and im driving it, and i floor it, the engine sounds like its working much faster but im not going any faster.
any ideas?
-Rick
Old 11-14-2005, 06:18 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Engine boggs out.
When it bogs out, does it smoke? If it does and the smoke is black, your running too rich, back off the fuel. If there's little or no smoke, there's a few things to check. I can't recall offhand what base timing spec's are,(10 Degree's Before TDC???) but unless your running an aftermarket cam/heads/etc.., it would be best to return it to base timing(base timing means vacuum line on distributor removed and plugged, engine idling. Assuming your engine vacuum is good, the vacuum advance needs to work properly. The easiest way to test is with a timing light(with vacuum advance hose connected to distributor). record timing while the engine is idling, then record again with engine revved above 2,000 RPM. If there is a noticeable difference, the vacuum advance is probably working. As for the 2nd question: I hate to be the bearer of bad news, but from what you described, the clutch is badly worn and needs replacing.
Old 11-23-2005, 06:17 PM
Unclewaltsoup Unclewaltsoup is offline
Send a message via AIM to Unclewaltsoup
how hard is it to replace the clutch? could i do it in my garage with limited knowledge and a book?
Old 11-24-2005, 04:38 PM
You'll have to seperate the engine and transmission to access the clutch. A book will definitly help. And you'll need plenty of tools.
