Old 12-09-2011, 10:20 AM
Ami Ami is offline
Unhappy 2004 dodge caravan windcreen washer
i have a 2004 dodge caravan when i press windscreen washer just the wipers go on
no water comes out
could it be the pump or there are seperate fuses
Old 12-09-2011, 01:54 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2004 dodge caravan windcreen washer
Frozen line? Low fluid?
There's no fuse. Power is supplied by the Front Control Module (FCM) via the switch and the Body Control Module (BCM).
The pump is on the bottom of the bottle accessed through the forward part of the passenger side front wheel well liner. Check for power at the connector. If it's there with the switch on and the ground is good, change the pump.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 12-10-2011, 03:44 PM
bignoisey bignoisey is offline
It could be frozen. Did you check the rubber tubes carrying the fluid to the wipers? They sometimes crack and the fluid never gets there.
whine from 2004 Dodge Caravan samtheman22 Caravan | Voyager 1 01-26-2009 06:37 PM
2004 dodge caravan won't start LITTLE D Caravan | Voyager 7 08-01-2008 10:42 AM
2004 Dodge Caravan - PCV removal dandy12 Caravan | Voyager 3 04-24-2008 07:09 PM
