Old 12-07-2011, 08:33 PM
jashurst jashurst is offline
97 Chevy s10 miss under load
Ok I haver been reading this one, I do have a question for old_master.
I have a 1997 S10 2.2L with a random cylinder misfire. I have replace all sensors except the air intake and cam position. I have replaced the ICM and all coils. New wires, plugs, injectors,timing chain and the EGR valve. I can start the truck as long as I do not let is sit for too long it will not give a P0300 code. It lacks power and is hard to start after it has been driven for a few miles. I took it to the dealer and they told me the #3 coil had weak spark, so I changed it out with no luck. Compression is good fuel pump and regulator are new. I took it to another shop and they told me that they can not determine what it is. What now the engine wiring harness?
Old 12-07-2011, 08:56 PM
old_master's Avatar
Advisor/Moderator
Re: 97 Chevy s10 miss under load
Exactly what DTC's are in memory, and what order are they in?
What brand and part number are the spark plugs that you installed?
You have to know how it works,
to figure out why it doesn't.
Old 12-07-2011, 09:41 PM
AC delco plugs and the only DTC is P0300
Old 12-07-2011, 09:47 PM
old_master's Avatar
Advisor/Moderator
AC Delco is good, what part number are the spark plugs?
What is the fuel pressure with the key on and the engine off?
What is the fuel pressure 10 minutes after the pump shuts off?
What is the fuel pressure at idle?
It also lopes at the idle at first but no vacume leaks detected.
Old 12-07-2011, 09:49 PM
According to the dealership the fuel pressure is good the compression is good. I have no way to check it myself.
Old 12-07-2011, 09:50 PM
The spark plugs are the recomended part number.
Old 12-07-2011, 09:54 PM
ac41-928
Old 12-07-2011, 09:58 PM
old_master's Avatar
Advisor/Moderator
The dealership told you the 2-3 coil pack was bad and it wasn't, how do they know the fuel pressure is good?
Need to start with the basics:
P0300 is almost always caused by a secondary ignition fault. Occasionally low fuel pressure or excessive leakdown will set it also. Some of the auto parts stores rent fuel pressure testers... very easy to check it. 41-928 are the correct plugs, thank you.
Old 12-07-2011, 10:21 PM
Not sure was not there to see it. I will check it and let you know.
Old 12-07-2011, 10:22 PM
Good night
97 Chevy s10 miss under load metalman55 Problem Diagnosis 31 05-11-2015 11:19 PM
91 Chevy s10 p/u with a high idle. need help! IndianaRedneck S-10 2 12-19-2010 09:14 AM
5.7 missing under load. Out of ideas..HELP LastOne C/K 7 03-21-2004 10:52 AM
Missing under load FordInPossession Crown Victoria 6 01-08-2004 06:43 PM
Engine misses under load RansomEli C/K 1 11-18-2003 06:08 PM
