Old 12-07-2011, 07:27 PM
crazy4jd318 crazy4jd318 is offline
91 floods out
My old plow truck is giving me fits, it idles great, put it in gear it floods out, put in park or neutral rev up and it clears back out, the temp sensor reads 85 degrees c on my scanner, has code 33, but i attribute that to flooding out causing erratic rpm, it lopes, I have replaced the spark plugs, wire cap and rotor, o2 sensor and map sensor, flushed and filled cooling system,I was advised a dirty cooling system can cause residule voltage, I also have switched throttle bodies and checked the fuel pressure and it is in specs, any thoughts on what I am missing? Also when put in reverse or drive it will run fine, but as soon as you crack the throttle it starts flooding out, the MAP sensor voltage at idle is 1.08 and the kpp is 31 and when it is flooding out it is 3.94 volts and 83 kpp
any insight would be great
Old 12-07-2011, 07:40 PM
j cAT j cAT is offline
Re: 91 floods out
you think the intake manifold has a crack. exhaust gas is getting into the engine intake .
at idle the MAP a little over 1 volt is good , 4 volts is WOT or very low vacuum....
Old 12-09-2011, 01:23 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 91 floods out
I'd check the coolant temp sensor and the wires to it as well as the IAC and EGR valves. Any one or combination thereof can cause poor idle and stalling in gear.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 12-09-2011, 01:46 PM
Re: 91 floods out
if the EGR spring is weak it is very possible this is his problem. this would cause the map voltage to shoot up ..
Old 12-11-2011, 07:59 PM
Re: 91 floods out
Well, had an opportunity to mess with the truck today, unhooked vacuum line to egr valve and plugged off, runs great, now need to deturmine what is causing the problem, bad egr valve or something else, since this activated a check engine light
Thank you for your thoughts so far, gave me something else to check
Old 12-13-2011, 07:36 AM
Re: 91 floods out
egr valves don't last forever. the spring and diaphram do fail over time by small amounts . if the spring is weak the EGR opens too much. If the diaphram has a hole in it you get a large vac leak when the EGR is commanded to operate.
replace it ..
1994 camry flooding out. help? kris10 Camry/Camry Hybrid/Vista 1 04-17-2010 07:09 AM
truck is flooding out rober6 F Series 1 12-11-2004 08:53 PM
'91 Rodeo floods out when starting...help dnoel Rodeo | Passport | MU 4 07-01-2004 09:20 AM
runs great for about 10 min or so then floods out jlaw C/K 1 02-09-2004 10:20 PM
zc floods out-- need help nes1chil '71-'87 Civic | CRX 0 04-21-2003 02:46 PM
