Old 12-04-2011, 01:47 PM
lesabrefan lesabrefan is offline
Lower plastic elbow leaking after replacement
01 Lesabre
I replaced both plastic elbow connectors and after 2 months i noticed the lower one was leaking. So I disassembled everything again, put some silicone on the tensioner side, snugly fit the elbow into both the tensioner and the block and put everything back together. Before it was leaking from the tensioner side, now it's leaking a bit from the block side. I can move the elbow back and forth with my hand, so it does not look like it's as snug as it should be. What in the world can I do? I got the parts at Pep Boys, i believe they were Dorman.
Thanks
1996 Lumina 3.1 - 191K
2001 LeSabre Custom - 153K
2006 Explorer 4.0 - 55K
Old 12-04-2011, 01:53 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Lower plastic elbow leaking after replacement
I have heard that the Dorman elbows have problems. You may want to go OEM on those.
Old 12-04-2011, 02:45 PM
Tech II Tech II is offline
I heard it was the o-rings, not the elbow.....
Old 12-04-2011, 02:50 PM
So should i get OEM elbows or try the rings? Sucks that I wasted money on the Dorman (or what ever it was) elbows.
Old 12-04-2011, 03:15 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
We have discussed the leaking Dorman seals/o-rings before. No more than the parts cost, I would replace both elbows & o-rings with OEM parts. If you value your time, redo labor cost more than the parts, not counting the frustration factor of doing the job 2-3 times. Here is a diagram & parts list.
323
24503423 PIPE. Engine Coolant By-Pass. Heater.
PIPE,THERM BYPASS UPR(TO LWR INT MANIF.)(08.846). Required: 01For: C 3.8K(L36) (1999-2005) (1999 - 2005). For: H 3.8K(L36) (1999-1999) (1999 - 1999). $12.48
324 25537068 SEAL. Engine Coolant By-Pass. Heater. Throttle Body Coolant Supply. $1.42
341
12565082 PIPE. Engine Coolant By-Pass
PIPE,THERM BYPASS LWR. Required: 01For: C 3.8K(L36) (1999-2005) (1999 - 2005). For: H 3.8K(L36) (1999-1999) (1999 - 1999). $3.76
342
343 24502846 SEAL. Engine Coolant By-Pass. Engine Fan Coolant.
$2.86
The Following User Says Thank You to HotZ28 For This Useful Post:
jamyers (04-10-2012)
Old 12-04-2011, 03:17 PM
Guys, thanks!
HotZ28, too bad I did not see the discussion before (usually the dorman parts have always worked for me). Found these two GM parts on Ebay, they come with seals, do I have to get seals 324, 342 and 343 in addition to what's being sold here or is everything that I need is included?
http://www.ebay.com/itm/NOS-Genuine-...item27b848e978
http://www.ebay.com/itm/new-Genuine-...item2a1488ed0a
Old 12-04-2011, 03:40 PM
HotZ28's Avatar
AF Moderator Elite
Everything you need is included with the elbows shown. Good luck, you are doing the right thing!
Old 12-04-2011, 03:59 PM
HotZ28, thanks!
Old 12-04-2011, 11:07 PM
HotZ28's Avatar
AF Moderator Elite
Being the old Engineer that I am, not satisfied with hearsay, and in an effort to add a little clarity to the difference between the Dorman elbows/O-rings & OEM parts, I decided to go to my shop tonight, where I had a sample of both. It is obvious to me, that all parts are similar (very close) in dimensions. Actually, the Dorman O-ring measured .010 larger diameter than the OEM. When installed on the fittings, both had the same O.D. One thing I did notice, the OEM O-rings are much softer & flexible than the Dorman O-rings. Without knowing the exact nomenclature of the material used in both parts, I have to assume, the OEM O-rings are more forgiving to temperature fluctuations, than the Dorman O-rings. Most of the problems with the Dorman O-rings, are leaks experienced after the engine cools down (in cold temp) after being being driven at full temperature. Shown in the pics below, are some of the dimensions measured with a digital caliper to .000. BTW, I was not satisfied with only one measurement, so I took several of the same part & came up with identical measurements.
Dorman lower on left & OEM upper on right
OEM top elbow fitting ID
Dorman lower elbow fitting ID, which has the same O-ring as the upper elbow.
Dorman O-ring
OEM O-ring
Old 12-05-2011, 12:30 AM
enslow enslow is offline
I love it!
Unfortunately, I followed advice elsewhere to use the Dorman elbow with a skim coat of RTV. If only this thread had appeared to me 6 months ago.
Well, when it does leak, I'll pull the tensioner, pull out the Dorman elbow, and soak the RTV with carb cleaner. I believe carb cleaner sufficiently softens RTV for proper cleaning.
Then I'll go OEM.
Old 12-05-2011, 12:26 PM
I NEVER used RTV on those o-rings......I just make sure the opening they slide into is clean, and I use petroleum jelly on the o-rings....never had a problem , but then again, I never used Dorman either...
Old 02-22-2012, 11:45 AM
smackerquacker smackerquacker is offline
Do these elbows start to leak for a reason? Common problem. Thanks for the diagram as it appears I need to repair this on my 2002 LeSabre. It is leaking pretty good.
Old 02-22-2012, 12:30 PM
How much coolant is going to run out during this repair? Do I need or want to drain some or have a pan ready to catch it?
Old 02-22-2012, 08:36 PM
HotZ28's Avatar
AF Moderator Elite
Anything below the radiator fill cap will drain to the level of the item removed, or lower. If you are doing this in a garage, it would be best to put a drain pan under the car.
Old 02-22-2012, 09:37 PM
I saw someone said use vaseline to get the new O-ring in. Would something like plumbers grease be better? I dug around the bottom of the radiator and I don't feel a drain. Is there one and I just haven't found it yet? BTW thanks for all the help.
2001 Jimmy 4x4 4.3L misfire after replacing lower intake gsket enrico1750 Jimmy 1 03-31-2008 02:42 PM
Small composite elbow leaking Anti-freeze FRNTROW Impala | Impala SS 1 10-09-2007 08:49 PM
Oil Leak after replacing head 91 Honda Civic 1.5 SOHC TuffGI Let's get Technical! 7 09-20-2006 03:42 PM
Trans Fluid Leaks After Replacing Radiator brockroland Malibu 4 10-19-2005 02:07 PM
tranny leaking after replacing cv ax? help! tran_nsx Integra 3 08-01-2003 09:58 AM
