Old 12-03-2011, 06:36 PM
badgerfisher badgerfisher is offline
Front wheel bearing replacement
I have decided that my front passenger wheel bearing needs to be replaced on my 98 cavalier 2.2L. After reading this site and other references I have found that the procedure is as follows:
- Loosen lug nuts and loosen/remove 30 mm cv axle nut
- Jack car up on stands and engage e-brake
- Remove wheel
- Remove brake caliper and rotors
- Remove the 3 T-55 bolts
- Use slide hammer to get hub assembly off of axle
- Place seal into back of hub and bolt back onto axle
If I have something wrong please let me know.
Also, I have heard different opinions about whether or not it is necessary to detach the controll arm from the ball joint. Could someone comment on this?
Old 12-03-2011, 06:44 PM
Re: Front wheel bearing replacement
Also would someone be able to verify these torque specs?
t55 bolts - 70 ft/lbs
axle nut - 180 fl/lbs
Old 12-03-2011, 09:52 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
No need to seperate ball joint to replace the hub on your car. The torque specs you have look correct.
Old 12-04-2011, 08:28 AM
maxwedge maxwedge is offline
A990 racer
Check the axle nut, seems high, I remember about 135.
Old 12-04-2011, 08:41 AM
gmtech1's Avatar
Found them,70 on the hub bolts is correct. The axle nut is 144lbs ft.
Old 12-04-2011, 08:55 AM
jd-autotech jd-autotech is offline
yeah but i wouldnt set the e-brake.although saftey first maybe just chock the rear wheels unless u do use ur e-brake on a regular basis, be cause if u dont and apply the e-brake for the first time in years there is a good chance the cables will be rusted and wont release costing u more time and money
Old 12-09-2011, 09:18 PM
Thanks everyone. Changed the bearing today and fixed the problem.
Front wheel bearing replacement BoWhite Montana/Montana SV6 6 12-07-2005 06:24 PM
Front Wheel Bearings Replacement? sbursik Crown Victoria 4 04-14-2005 07:23 AM
Front Wheel Bearing Replacement markf C/K 3 09-12-2004 12:17 PM
front wheel bearing replacement gnailuh Off-Topic 0 03-17-2004 08:35 PM
