Old 12-02-2011, 12:19 PM
Bomgart Bomgart is offline
96 Z-71 Vent Controls Not Working Properly
My 96 Z-71 has had a vent control problem since I bought it used 4yrs ago. Mind you that the Heat and AC work perfectly it is just where the air is delivered is not. When on Def it comes out the dash and some on the floor. When on the floor some comes out the Def and dash. Its like something is not opening or closing all the way. I am handy with tools and what not but I suck if it is electrical. Anybody have this same problem and have a solution?
Old 12-02-2011, 05:21 PM
777stickman 777stickman is offline
Re: 96 Z-71 Vent Controls Not Working Properly
Welcome to AF. Not sure if you have vacuum or electrical controls. Look on the drivers side heat/ac plenum just to the right of the gas pedal. Sometimes the linkage from the Mode actuator comes loose or breaks. Should be 2 separate rods connected to 2 separate arms in the plenum.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-02-2011, 10:43 PM
It is electrical. I looked under there and there is a pivot point right next to the (looks like the controller). I followed it up and there is a spring in this part of the arm which leads to another pivot point. This point was crooked and appeared to be out of the socket. I pushed it back in and it feels like it is connected to something heavy. I suspect it is broke inside.
98 Bonnevile SE Climate control not working properly crazy8 Bonneville 0 06-22-2011 01:56 PM
Cruise control not working properly post tranny rebuild TCGrove Caravan | Voyager 4 08-12-2009 03:04 PM
2003 climate control not working properly junk yard doggie Sable 2 04-09-2006 09:16 PM
Cruise Control not working properly CamaroRS92 Camaro Discussions 4 09-08-2005 08:43 PM
vent control not working mz0dw4 C/K 4 11-25-2004 10:33 AM
