Old 11-13-2003, 12:05 PM
mz0dw4 mz0dw4 is offline
Question vent control not working
I need help in diagnosing this problem. The vent control quit working. and all air from the blower is going to the floor no matter what I turn the knob to. The blower control, hot/cold control and A/C and Recirc buttons seem to work. My vehicle is a 1995 1500 Silverado 2 wheel drive. Any help is appreciated. Thanks, Bill.
Old 11-19-2003, 12:17 AM
jlashbrook jlashbrook is offline
Re: vent control not working
I'm not to sure on the "newer" chevy trucks, but I had the same problem on an 80's model. The problem turned out to be a vacuum line that feeds vacuum to the heater control unit. This vacuum line goes through the firewall to the heater unit. On the older models, it was a small black plastic line that went through the firewall a little left of center of truck. This vacuum line must have vacuum on it in order to supply the necessary vacuum needed to control the vent work inside the truck.
Old 11-20-2003, 08:38 AM
Re: Re: vent control not working
Thanks, but on the newer trucks, I don't see any vacuum lines coming from the vent control module. Maybe there are vacuum lines going to other places but there are none going to the actual module where I control the vents.
Old 11-20-2003, 08:45 PM
99ssconv 99ssconv is offline
check the mechanical linkage just above the gas pedal to see if it has fallen apart, if not mode actuator or control head issues.
Old 11-25-2004, 10:33 AM
Bagalac Bagalac is offline
Send a message via AIM to Bagalac
i have the exact same problem and have replaced my controller 3 times.. they just keep going bad.. but for the record there is no linkage or vacuum controlled devices in these newer HVAC systems its all electronic...
2000 Windstar Air vents not working right olopezm Windstar 11 08-04-2010 09:09 PM
A/C Control Dual Zone switch assembly Not Working bigpoppabear Intrigue 4 06-22-2010 11:28 AM
Vent control not working in cold weather gp2001 Introductions 1 11-07-2005 09:01 PM
'95 Mustang heater/vent/air control not working Rusty88 Mustang Talk 0 03-31-2005 07:05 PM
