Cooling fans?
On my sons 1995 grand price with a 3.1 v-6 the drivers side cooling fan works with the a/c running but we cannot get the passenger side fan to run.
We have replaced the sensor next to the thermostat, fan motor and the relay located in the fuse box under the hood. Is there more relays and if so where? Please help if at all possible. Thanks |
Re: Cooling fans?
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
Re: Cooling fans?
If I was a mechanic that would probably help me understand it a little easier. Could it be the temp gauge is erratic and not working properly? Where is the sensor located that controls the temp gauge?
Re: Cooling fans?
Is the car overheating? The info I have states that the secondary cooling fan will only operate if the the coolant temp is above 235deg a/c on or off (as stated above) OR if the a/c pressures are above 236psi (typo above) and speed is less than 50mph and will shut off when temp reaches 228deg, a/c pressures are less than 185psi or the key is turned off. The car just may not be getting hot enough to turn on the fan. A scanner with pcm output controls would be able to command on the fan and verify operation and check coolant temps as read by the pcm.
Re: Cooling fans?
Just like GMtech1 said or in other words, one fan will work on a more regular basis depending on the engine temperature, AC on/off or if there is a problem with engine components (bad ECT for example).
The other fan will work when the temperature reaches 235F or you've been idling for extended periods of time in traffic. Oscar.
Re: Cooling fans?
Okay. We pulled the wires off the temp sensor switch that goes in near the thermostat housing and the passenger side fan started working. We replaced that sensor and then plugged the wire back and so far no fan.
Now it will trip the CES and when you place it in gear the CES will go off. ??? |
Re: Cooling fans?
You REALLY need a scanner so you can see what the actual coolant temp is, and now to see what code is set and clear it.
