Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-27-2011, 03:29 PM
jesselv jesselv is offline
01 Rodeo start problem but good battery
Turn the key on my Rodeo and nothing, then turn again it starts. No sound like it's even trying to turn over on the first try. Sound like the starter giving out, or something else? Second question; where is the starter on this thing? can't seem to trace it down from pos cable.
Old 11-27-2011, 10:04 PM
Cat Fuzz Cat Fuzz is offline
Re: 01 Rodeo start problem but good battery
Probably bad solenoid contacts. It's on the drivers side under the exhaust. If it's a 4x4, you'll need to unbolt the motor mounts from the frame, remove the drivers side mount from the engine, lift the engine then slip the starter out. All this can be done by putting the front on jack stands and removing the drivers front tire.
Check your battery connections and grounds first. Put a test light on the small wire on the starter and have someone turn the key, if it lights up without the starter cranking, you have a starter problem.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 11-28-2011, 06:53 AM
Clarification for total novice; I don't have a 4x4 so is removing motor mounts and lifting the engine still necessary to get to the starter? also, is it possible that there is a problem with the starter relay since it makes no sound when turning the key once but second time turns over? Sorry one more thing, can I use the test light anywhere besides right on the starter itself to make the check you suggested. Probably dumb questions but i need to ask. Thanks in advance.
Old 11-28-2011, 06:10 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Cat covered it very well.
If you are a 2x4 you should be able to wiggle it out.
Start with the battery connections and then it is probably time for a new or used starter.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
The Following User Says Thank You to amigo-2k For This Useful Post:
jesselv (11-30-2011)
Old 11-28-2011, 07:58 PM
To eliminate the relay being defective, locate it with your owners manual and simply swap it with another relay that you know works. In my experience, relays rarely fail especially in a car this age. Also, no, you shouldn't have to lift the engine. Starter should drop right out without a front differential in the way.
The Following User Says Thank You to Cat Fuzz For This Useful Post:
Old 02-01-2012, 04:57 PM
ajimenez ajimenez is offline
This happens regularly on my wife's 03 Rodeo. Turn the key and there is not a sound. Turn the key another time or two and it starts and runs fine for weeks sometimes till it happens again.
My Fiat Punto Car Wont Start Ilhanx64 Punto | Idea | Punto Grande 2 10-21-2010 06:14 AM
94 rodeo starting problems janec Rodeo | Passport | MU 7 02-11-2006 10:16 PM
2001 Rodeo starting problems - linked to Alarm? hroark7 Rodeo | Passport | MU 3 01-17-2006 07:40 PM
1999 Isuzu Rodeo Starting Problems ammosman Rodeo | Passport | MU 2 10-28-2003 10:15 PM
1992 Rodeo starting problem rodam Rodeo | Passport | MU 6 10-25-2003 07:21 PM
