98`p71
4.6 sohc.
When i start up the engine(cold) Their is a loud clicking sound. And when it is doing this it looks like the belt is going to jump off the crank (Harmonic balancer)and the belt tensioner is jumping! ![]() Once the motor is warmed up it stops. The harmonic balancer is wobbling somewhat. Could the balancer be the problem? Thanks |
Re: 98`p71
It could definitely be a problem! If the harmonic dampener (these engines are internally balanced) fails, the belt will slip off, and who knows what can happen with a flying off harmonic dampener.
Replace it if necessary and use a brand new bolt since it is a one time use torque-to-yield bolt.
![]() 2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
| The Following User Says Thank You to Blue)(Fusion For This Useful Post: | ||
Mark72 (11-30-2011)
Re: 98`p71
Thanks for the reply.
I think that the crank pully is the problem. Thanks again |
