Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-28-2010, 12:49 PM
Mark7234 Mark7234 is offline
Banned
98`P71 Trans ?
Under hard acceleration it wont shift from 2nd to 3rd unless i let up.
Any ideas?
Old 09-28-2010, 01:22 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 98`P71 Trans ?
It won't EVER shift, staying in 2nd as long as you hold the gas down, or does it shift later than you would like?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-28-2010, 03:15 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 98`P71 Trans ?
Did you or any previous owner put in a higher rear end gear ratio gears? If so and a re-tune was not performed, the rev limiter may be reached before the 2-3 shift speed (in MPH) is reached and it will bounce off the rev limiter in 2nd gear.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 06-21-2011, 12:19 PM
Mark72 Mark72 is offline
Re: 98`P71 Trans ?
I don`t Think it has been modified.
Their are no codes comming up,I was thinking shift sensor?
Its an old police car 240,000 miles.also when accelerating the RPM races up before it shifts hard into 3rd.Changed the fluid and filter but it didn`t help.
Any and all ideas would be appreciated. Thanks
Old 06-24-2011, 05:29 PM
Re: 98`P71 Trans ?
So 9 months later, it's still doing the same thing? Asking again - so it will NEVER shift unless you let up, right? My '93 did the same thing, now that I'm thinking about it.
Old 08-16-2011, 06:35 PM
Re: 98`P71 Trans ?
That is correct,I have never held it over 4500 rpm but it won`t shift till i let up.
98 P71 Rod Knock longknife58 Crown Victoria 2 05-11-2010 09:25 PM
what works for a 2000 P71? jx426 Crown Victoria 6 03-17-2009 04:34 PM
p71 trans wap slash09 Crown Victoria 0 10-26-2008 09:12 PM
98 P71 new/used trans but doesn't move dizzle1 Crown Victoria 2 06-14-2008 03:48 PM
98 P71 side marker bulb replacement lights_sirens Crown Victoria 5 03-15-2006 07:04 PM
