Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-14-2006, 01:40 AM
lights_sirens's Avatar
lights_sirens lights_sirens is offline
Question 98 P71 side marker bulb replacement
I need advice on removing the front side marker bulb on my '98 CVPI. The one on the drivers side has been burned out since I bought the car at auction over 2 years ago. After I removed the long black cover under the hood there isn't enough room for my hand to reach in and pull the bulb out of the housing.
Old 03-14-2006, 09:15 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 98 P71 side marker bulb replacement
If you mean the one on the outside of the fender, not the turn signal, there are two 7/76 or 11mm nuts on the inside of the fender. Remove these and there is a screw on the outside of the lens. Take the entire lens assembly out to change the bulb.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-14-2006, 10:28 PM
Thank you for your quick reply and information! Yes, it's the one on the outside of the fender, not the turn signal. I found the screw and one of the 7/16 nuts. I think I'll find the other 7/16 inch nut on the lens housing after I remove the air box and windshield washer reservior, but it will be worth the effort to have lights again.
Old 03-15-2006, 03:35 AM
raiderman2k3's Avatar
raiderman2k3 raiderman2k3 is offline
The easiest way to change the side marker light is to remove the headlight module first. There are 2 metal tabs you pull up on toward each end to release the module, then push the module from the inside toward the front of the car to loosen. Twist the bulb sockets Counter clockwise to remove.
When the headlight out of the way, you can reach in and turn the marker light bulb socket C/C, and pull it back to remove.
This took less than 2 minutes to remove, replace the bulb, and reassemble.
Old 03-15-2006, 11:44 AM
way2old's Avatar
TOKEN HILLBILLY
Look in the metal brace. There is a hole there. I think the bottom bolt goes inside that hole.
Old 03-15-2006, 07:04 PM
I just found a photo essay on the headlight removal process; http://www.crownvic.net/liquid/headlight.html
Thanks again guys.
