Old 11-23-2011, 09:12 PM
Scottm69s Scottm69s is offline
2002 Cavalier leaking antifreeze from tube?
Hi, I have a 2002 Cavalier 2.2l and am trying to figure out a part that is leaking. There are a bunch of skinny metal tubes that go from the engine somewhere down under the drivers side door. One of the tubes has a connector piece in one section and the fluid is antifreeze. Does anyone know what that part is called. i have uploaded a photo.
Old 11-23-2011, 09:44 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2002 Cavalier leaking antifreeze from tube?
Thats a brake line leaking at a proportioning valve for the rear brakes. It helps prevent rear brake lock up. They may also be called residual pressure valves.
1997 cavalier leaking antifreeze 1997cavalier Cavalier Problem Diagnosis 5 01-10-2010 02:06 PM
97 Passport Leaking Antifreeze from Under Glove Box bigscreaminjack Rodeo | Passport | MU 12 05-15-2007 06:23 PM
97 Passport Leaking Antifreeze from Under Glove Box bigscreaminjack Let's get Technical! 1 05-15-2007 09:48 AM
2000 Passat Leaking Antifreeze from bottom of car BADPASSAT Passat 0 03-28-2006 12:15 PM
leaking antifreeze from top rear of engine 5.7 gmc18201 General Discussion 1 09-30-2005 07:59 PM
