Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-15-2007, 09:14 AM
bigscreaminjack bigscreaminjack is offline
Question 97 Passport Leaking Antifreeze from Under Glove Box
Any Suggestions?
I noticed a leak while driving back from a camping trip last weekend. I thought it had stopped but this morning I saw smoke wafting up from below my glove boxand pulled the car over to see a dripping leak of antifreeze coming from the center column underneath the dash. I think the smoke was caused by the antifreeze running on to a hot piece of metal.
As is probably apparent, I'm not the best mechanic. I'm just wondering if anyone else has experienced this problem and what they did to fix it. My thought is to check my coolant level and try to tape the leak using some electrical tape.
Any suggestions are welcome.
Thanks,
Travis
Old 05-15-2007, 09:21 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 97 Passport Leaking Antifreeze from Under Glove Box
Your heater core is leaking. You can add some stop leak which will probably stop it for a couple of years or you can replace the heater core (750-1000 bucks by a mechanic).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-15-2007, 09:51 AM
surferfletch surferfletch is offline
Or you can DIY for the cost of the part (<$50?) and a weekend of pulling the dash out. It's the sort of thing that can get much worse quickly. And I now see you're not the best mechanic, so....
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 05-15-2007, 09:58 AM
Hmmm, Pulling the Dash out sounds a bit complicated.
Tell me more about this stop leak. I searched online and found AC stopleak. Is this what your referring to?
http://www.jcwhitney.com/autoparts/P...10101/TID-0820
Old 05-15-2007, 10:04 AM
It's for your heater core, which is a mini radiator in your dash. You need a cooling system stop leak, or radiator stop leak.
Old 05-15-2007, 10:07 AM
http://autos.yahoo.com/maintain/repa...ques015_2.html
I don't like stop leak products. I did my Jetta heater core in a weekend without ever doing one before. It was a collossal job, but it was a ton cheaper than a mechanic.
Old 05-15-2007, 10:16 AM
Could you define a collossal job for me?
If something easier would fix it for 1 year, I'd take it.
Thanks
Old 05-15-2007, 10:52 AM
Lots of screws and bolts to remove. Not too long ago, someone posted pictures of the dash pulled out for a heater core job. If you have a full day, you could probably get it torn down and put back. There is just no guarantee the stop leak will get it done, even for 1 year. You don't know how big the hole or crack is without looking at it.
Old 05-15-2007, 11:01 AM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
If you're going to keep the truck I would invest the time to repair it. As odd as it may seem, it would be a great learning experience. Just make sure you bag and label the nuts/bolts. I took a look at the Haynes manual and it doesn't look that difficult just very time consuming. Swing by a parts store and take a look at a manual.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 05-15-2007, 11:22 AM
http://www.automotiveforums.com/t658...hellll___.html
Well, after reading 96 heater core hell, I'm not sure whether I should undertake this challenge. I guess I'll do some more reading to see whether I can handle it or not.
Should I not drive the vehicle until I get it fixed? I'm going to go check on it at lunch to see if it has continued leaking even when not running.
If I try the stop leak stuff, will there be potential that it will cause more damage, or just be futile?
Thanks
Old 05-15-2007, 02:25 PM
Isuzu Guy
I've used stop leak before (Bar's Stop Leak; it's been around for over 50 years). It stopped my radiator leak for about 2 years, and then it started again so I put in a new rad.
Stop leak basically coats your whole system and narrows the passageways in the system (that is the bad).
If you are planning on keeping the truck for +2 years I would pay to have someone swap it out. If not, dump in some stop leak...
-Ryan
Isuzu Moderator
Car Show Tips
Old 05-15-2007, 04:36 PM
Ramblin Fever Ramblin Fever is offline
Agree, if the truck is in otherwise excellent condition, and you plan to keep it for more then a year, fix it right.
If you're only keeping it for 6 mnths or so, do what you have to do to get by.
I don't like, and have never used stop leak products, as they can inhibit cooling capabilities and cause blockage, allowing the engine to overheat, which - on these trucks, being an all aluminum engine, you can blow a head pretty easily.
It's all based on whether or not you plan to keep the truck, this is what we should have done with our 22yr old Toyota truck when the 2nd headgasket started weeping, as we only got another 70k out of the truck anyway, even after the 3rd headgasket was replaced.
IMHO, if your Rodeo has less then 200k and is in good condition, it'll go for a long time yet, you just need to decide if you're going to keep it or not as to justify the cost, or if it's being sold to family/friends, fix it right or you'll regret it.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-15-2007, 06:23 PM
2000izusu 2000izusu is offline
if it is a real beater (urban battleship)you can bypass the heater core. it is free but you won't have any heat! it is a good temporary fix to. mike
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
